Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th November 2011, 08:01 PM   #1
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
Default Faulty Connexelectronic SMPS2000R [Resolved]
Hi all,
I ordered two SMPS2000R power supplies to power my Tripath TA0105A amps. One works OK but the other was dead on arrival. I have tried everything to get help from Cristi, but to no avail. I've even recorded videos of my attempts to debug the circuit and posted it on YouTube. Cristi tells me that video sites are blocked where he comes from, so I hosted the video on my site. Apparently that didn't work either...so I cut the video into 5 and emailed them, but that didn't work either...
Next was Skype - but you both have to be on at the same time for that to work...now all attempts to communicate via email have gone unanswered.
Two questions:
  1. Has anyone else had this problem with Connexelectronic?
  2. Any ideas how to debug the SMPS2000R?!
Thanks!
Gareth
Old 29th November 2011, 08:15 PM   #2
norazmi is offline norazmi  Malaysia
Good information, have u try ask him with cristi sales thread at marketplace? maybe u can get some information there, btw i dont have any idea about smps2000r, it cost more than $100 i think..
Old 29th November 2011, 08:32 PM   #3
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
what have you checked on it?
where are the vids?
is pretty simple circuit, switching supplys
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 29th November 2011, 09:30 PM   #4
Rarkov's Avatar
Video here: Testing the Connex Electronic SMPS2000R - YouTube
This is what's happening:
  1. Checked all fuses on board with continuity meter - all fine.
  2. Connected the board to the mains (240V) using the Live, Neutral and Earth wires with 13amp fuse.
  3. Turned on power from mains and POWER LED turned on
  4. Measured +ve rail to GND: 0V
  5. Measured -ve rail to GND: 0V
  6. Measured +ve AUX to AUX GND: 0V
  7. Measured -ve AUX to AUX GND: 0V
I was asked to check pads 1, 2 and 3 from the attachment which measured as follows:
  1. 2.7V
  2. 10.56V
  3. 12.57V
Apparently, they should have measured:
  1. 12.5 - 15V
  2. 11 - 13.5V
  3. 16 - 22V
Thanks for any help!!!
Gareth
Old 29th November 2011, 10:40 PM   #5
luka's Avatar
I don't know what those are, but check if IC has power, if its oscillator is working, if it is outputting anything on its output and so on
Led could be just to indicate that main capacitors are charged... nothing important
Do you have scope?
I FEEL SLOVENIA
Old 29th November 2011, 10:51 PM   #6
Rarkov's Avatar
Thanks luka,
I have a scope, but its been a good few years since I've used it! I'll have to dust off my memory! I'll check the board tomorrow and find out what the IC is and grab the datasheet.
Again, thanks for your help!
Gareth
Old 2nd December 2011, 11:09 AM   #7
Banned
I was looking to buy the 500W version of that SMPS. will I face same issues?
Old 2nd December 2011, 06:36 PM   #8
luka's Avatar
its still unknown what is wrong
I FEEL SLOVENIA
Old 3rd December 2011, 01:19 AM   #9
! is offline !  United States
Basically you just use the multimeter to trace the circuit, the path the current flows from input to output to see where the values aren't right anymore.
There seems to be a typical line filter, then at bridge rectifier input you should still have near 240VAC, then on the output you'd have about 335V DC, then tracing over to one or more switching transistors you'd have their base driven by the control circuit, and an emitter and collector voltage levels (or mosfet gate, drain and source pins). If no voltage is coming out of the transistors and they are driven at their base still, suspect transistor fault. If there is no base drive, begin tracing the control circuit. Locate the control IC and its datasheet or make a schematic of a discrete design to better understand what to measure in it.
If on the other hand you still have a good voltage level going into the transformer, measure at the transformer output (secondary) windings too.
It helps that you have one that works ok because you can compare readings between the two. Just be careful, playing with line powered power supplies is potentially dangerous. Some would advise hooking this up with a light bulb in series on the AC input to limit current.
Old 3rd December 2011, 05:57 PM   #10
Banned
I think you should ask for a return of this power supply, if its faulty already
A schematic will help you to fix it also.
finding the right AMP from connexelectronic _henry_ Connexelectronic 4 2nd April 2013 05:54 AM
Connexelectronic vs zoe_tsang amps Frosteh Class D 6 2nd February 2012 06:46 AM
TMC or TPC my dilemma resolved? dadod Solid State 23 2nd May 2011 08:23 AM
denom pma250 amp faulty,but no faulty parts found please help homertooties Solid State 1 7th December 2008 03:58 PM
Copyright ©1999-2013 diyAudio
