Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th November 2011, 02:14 PM   #1
dclapp is offline dclapp  United States
Default No caps power supply!
This guy, who obviously knows what he's doing, uses a power supply with NO caps whatsoever!
Scroll down to power supply at
Mick Feuerbacher Audio Projects
Thoughts? Has everything I've been learning been wrong? :-)
Thanks for your comments and wisdom, brothers.
Old 29th November 2011, 02:19 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Well practically speaking it does have caps. 2200uF on each leg on each channel. They are next to the chip.
Old 29th November 2011, 03:00 PM   #3
DF96 is offline DF96  England
My thoughts:
1. No caps, just the caps which are already there. Ooops, that means caps!
2. Why build a fancy case for a basic chip amp?
3. Why minimise external components when the inside of the chip is crammed full of components?
4. Hanging caps off the pins of the chip may be asking for reliability problems later on, and could also make it harder to ensure ground currents go where they should.
5. He can get away with all this poor engineering because the chip itself has been designed and built by real engineers, so it is robust and has low PSRR etc.
Old 29th November 2011, 04:00 PM   #4
I would suggest 1,000uF on each channel on the chip amps,
and 1,000uF or more on each channel in the power supply.
The large charging pulses of remote only capacitors is not
good regarding power supply wiring radiation and the peak
current through any PS connectors. Small capacitors put
directly across each bridge diode is also good for noise.
I cannot see anything to recommend the approach taken
regarding the use of a separately cased power supply.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 29th November 2011, 08:35 PM   #5
Elvee is offline Elvee  Belgium
Building a really cap-less power supply is not difficult, but you have to really know what you are doing.
Of course, this is just an exercise in style, since caps are much cheaper and much closer to perfection as energy-storage devices than anything else, but just in case:
As for the construction style, I heavily recommend the "Shanty Town Paradigm": the electrons being totally disorientated by the "Fuzzy Wiring Concept", they become utterly unable to generate nasty resonances, thereby greatly improving reproduction qualities.
(Parallelipeped copper blocks are known to promote resonances)
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 29th November 2011, 08:43 PM   #6
Hi, Well I don't think he does, its style over substance, rgds, sreten.
Old 30th November 2011, 11:39 AM   #7
marce is offline marce  United Kingdom
And all that long wiring full of 50/60Hz ripple...
Old 1st December 2011, 06:48 PM   #8
Maybe this is what you are looking for:
No R, No C, No Batteries, No Hum
It also references this design:
http://greygum.net/sbench/sbench/norc_pa.html
Old 1st December 2011, 07:03 PM   #9
An Amp with no R's and no C's
Well well, little did I suspect when I proposed the circuit above that somebody had already been fool enough to actually use it.
But I am glad I didn't see it before I proposed my version: mine doesn't rely on non-linear elements like regulator tubes, and behaves essentially like a simulated capacitor, with only one layer of power inductance.
Old 3rd December 2011, 02:48 AM   #10
Compare the energystorage, loss, price, size and weigth of a cap to those of a equivalent
inductor and you will see how silly it is to use only inductors as energystorage device. The
only area where inductors trumpf is at temperature, lifespan, or endurance extremes.
Usually the best results are obtained by using the best possible compromise for a certain application, and that almost always will include caps, especially in powersupplies.
power supply caps bugust Construction Tips 3 25th July 2010 07:51 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
Power supply caps Ellen Parts 4 4th July 2003 02:11 AM
Power supply caps diy student Solid State 2 6th September 2001 12:04 AM
Page generated in 0.11345 seconds (77.55% PHP - 22.45% MySQL) with 11 queries
