I'm doing some repairs to my tube amp ,and I found this ........
![]() ![]() when I remove one of the capacitors was broken at that point the gold sheet,........ any ideas on parts, solutions etc. Thanks. ![]() ----------------------------
"Liberty is the right of every man to be honest, to think and to speak without hypocrisy." José Martí (1853 to 1895) |
#2 |
Trim the trace that's sticking up, install the new cap, and run a piece of wire from the capacitor lead terminal to the lead of the white power resistor.
#3 |
Is this a double sided PCB, with copper traces on both the component side and the underside?
Check for damaged traces on the underside. Repair if necessary. |
#4 | |
"Liberty is the right of every man to be honest, to think and to speak without hypocrisy." José Martí (1853 to 1895) Last edited by juliovideo; 29th November 2011 at 06:07 PM. |
#5 | |
thanks ! ![]() -----------------
#6 |
Some progress in rebuilding........
Paint Power box. ![]() Change Power transformer ,the old transformer it burned ![]() Primary : 110-120 VAC ---- Black - White = 120 volts AC Secondary 1: 0-360-380 VAC, 800 mA ------------------- Blue - Red/Yellow - Red) Secondary 2: 70 VAC, 100 mA -------------------------- Yellow - Yellow Secondary 3: 3,15 VAC - 0 VAC - 3,15 VAC, 4A --------- Green - Green/Yellow - Green Secondary 4: 3,15 VAC - 0 VAC - 3,15 VAC, 4A --------- Brown - Brown/Yellow - Brown Orange ----------------------------------------------- Electrostatic Shield ( Ground ) PARTS Heyboer transformers with electrostatic shield - Lay Down ... $ 141.00 Heyboer Transformer - Top Turret Lugs for Epoxy Board 1/8" G-10 Board - Black Anvil & Swage Turret Kit Tin Plated Copper Buss Wire How to Build a Turret Board - Part 1 and Part 2 Power cable. Belden 83803 12 AWG 3 http://www.parts-express.com/pe/show...number=100-790 AC Power Cord Male Plug - Rhodium http://www.ebay.com/itm/300458128323...#ht_2026wt_905 --------------------
"Liberty is the right of every man to be honest, to think and to speak without hypocrisy." José Martí (1853 to 1895) Last edited by juliovideo; 29th November 2011 at 07:00 PM. |
| Switching Power Supply Board | Perry Babin | Car Audio | 0 | 14th September 2011 03:11 AM |
| F3 pcb + power supply board for sale | h_a | Group Buys | 7 | 26th February 2009 05:14 PM |
| F3 pcb + power supply board for sale | h_a | Swap Meet | 6 | 23rd February 2009 04:14 PM |
| Power Amplifier PCB-layout / Board design | Jan Dupont | Parts | 4 | 10th February 2004 08:35 PM |
| Symetrical power supply PCB board needed | supernet | Solid State | 6 | 19th June 2003 09:24 PM |
