Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th November 2011, 11:36 PM   #1
swipesy is offline swipesy  United States
Default Voltage Tripler with Diode Bridge?
Hi all. I'm designing a replacement power supply for a mixer which requires +/-15 @ 2.4A, +8V @ 300ma and +48V phantom @ 320ma (absolute maximums), and am purposefully overdesigning it for reliability. I'm using a 2x18VAC toroid trafo with dual secondaries, one for +15V/5A and the other for -15/5A. Both would employ bridge recifiers and 5A 3-pin regulators, tying the (+) output of one to the (-) output of the other for 0 volts. The +15V rail would be sent through an additional regulator to get +8V. The -15V rail would be used to power the cooling fan, LED displays, etc., to help equalize power use. Pretty standard stuff there really.
Now here's the big question for me, as I'm a little shaky on this. I'm attempting to combine a full-wave voltage tripler with the +15V rail's bridge rectifier to generate the pre-filtered, pre-regulated DC voltage needed for the +48V rail. I've come up with the circuit in the attached pic.
Is the schem correct, at least in principle? I don't want to use a second trafo unless I absolutely need to.
Thanks in advance!
Old 28th November 2011, 09:21 AM   #2
Elvee is offline Elvee  Belgium
Your schematic is not clear (where is the center tap, etc), but anyway, it is not the right way to do it.
You should use a single bridge for the +/15V, and a separate multiplier for the 48V.
Trying to reuse the +15V as a base voltage for the tripler wouldn't be a good idea, because of the drawbacks and because you don't need it: with the CT winding, you can spare a stage anyway.
See example:
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 28th November 2011, 01:23 PM   #3
There is no center tap. Sorry I didn't make that clear, I thought it would be understood with my explanation.
Old 28th November 2011, 01:56 PM   #4
tinitus is offline tinitus  Europe
Voltage Doubler, Tripler
how can you get two voltages, without having a ground ?
Old 28th November 2011, 02:19 PM   #5
You said you have dual secondaries. You are free to connect them yourself in a CT configuration. You just have to wire them in series.
Old 28th November 2011, 02:30 PM   #6
if you have a dual secondary then it can be converted to centre tapped as already explained.
However, when using a single bridge rectifier to produce a dual polarity supply, you can only use a centre tapped transformer.
If you have dual bridge rectifiers for dual polarity supplies you can only use isolated secondaries, one to each bridge rectifier.
If you need additional power from those secondaries, then you cannot use both, you must use one secondary only.
You will find that the third power supply is not completely isolated from the the "normal" dual polarity supplies.
If your phantom PSU needs isolated power, then I think you need a third winding.
regards Andrew T.
Old 28th November 2011, 03:55 PM   #7
Let me try to explain something, which I attempted to explain in my first post but appears to be a total failure. I know I can connect the secondaries to make a CT, but I am not doing that. I am using one secondary for the +15V rail - bridge rectifier, caps, regulator, etc. So far, so good. Now, the other secondary is being used for the -15V rail - bridge rectifier, caps, regulator, etc. (same as for the +15V rail), but configured as a floating rail so I can connect the normally positive output to ground, thereby creating the -15V rail.
I hope I have cleared that up.
So, using that scheme I have only the secondary used for the +15V rail to generate the +48V. Using a voltage tripler, or even a quadrupler (power requirement is relatively minimal), seems the best bet. Trouble is, I'm just not that familiar with them. I could always use a step-up trafo (or a power trafo in reverse) directly off the secondary to generate the higher voltage. I've done that before with a trafo I had on-hand, but I would prefer to use a tripler or quadrupler to avoid the extra trafo cost if I can. The circuit I came up with was a combination of a standard bridge rectifier and a full-wave voltage tripler with common-connected elements used for both.
Old 28th November 2011, 04:34 PM   #8
Why are you doing that? Even if your 48V requirement is not taken into account, it has a number of disadvantages.
The only reason for doing it would be the ability to use a positive regulator, but that would be a bad reason, especially with a toroidal transformer.
Old 28th November 2011, 04:41 PM   #9
Hmm. Well, using a negative regulator over 2A isn't a good idea either, right? I had read it was a good idea to do it that way, so I'm going to have to research this again. I've used negative regulators before but those were for low-power supplies.
Old 28th November 2011, 05:20 PM   #10
Many thanks to everyone for the replies. I'd say it's apparent I've been looking in the wrong places for help with this design before now. My fall-back position always was to use separate power transformers for each voltage. I have to get the mixer back in service very soon and don't have enough time now to figure this out so it looks like that's what I'll have to do. I'm more of a builder than a designer anyway, and I really have to get started building. 32-channel mixers aren't cheap and I need to use it on New Year's Eve. I was hoping to reduce my PSU costs, but it is what it is. Again, thanks!
Voltage doubler, tripler or other creative solution? markusA Power Supplies 6 28th March 2010 07:49 PM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Voltage doubler/tripler circuits diablo Power Supplies 6 4th October 2005 04:43 AM
voltage-tripler diode values?? rockstudio Power Supplies 4 17th June 2005 05:58 AM
Page generated in 0.12439 seconds (81.03% PHP - 18.97% MySQL) with 11 queries
