Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th November 2011, 01:30 PM   #1
Default What to make of this regulator?
Hello,
I have thsi regulator left from another project, wondering how good it is, if used for a 150mA or so preamp project. I will have to change the zeners for appropriate voltage.
Any improvements suggested?
Thanks!
Old 26th November 2011, 01:36 PM   #2
note that the opamps are supplied by the unregulated voltage at the smoothing caps.
What is the maximum operating voltage of the op249g?
I suspect a 9V transformer already takes them to within a few % of maximum operating voltage when taking worst case conditions into account.
regards Andrew T.
Old 26th November 2011, 01:45 PM   #3
Supply from datasheet is Min 4.5v Typ: 15v, Max 18v. Thanks for the tip, as I was planning to get closer to 18v, now have to be careful.
Old 26th November 2011, 02:02 PM   #4
9Vac already takes the device way past 18Vdc.
Could the 249 specification actually be <=36Vdc?
regards Andrew T.
Old 26th November 2011, 02:52 PM   #5
Correct, I assumed otherwise. I looked at the PCB and found errors in the schematics.
Actually I have 2 versions of this supply, and there was a mistake in the schematics around the OPAMP output (fixed). I've attached both.
One is 5v (in use) and concerned about the 18v OpAmp supply.
The second is a 15v one I'd like to use for 16-17v supply (by changing the zeners). However not sure about the 10v Zener...
And overall, is this design any good? Should I fix the 9v one and further improve the 15v one?
Possibly, the first schematic (top post) might have been a suggested fix, I forgot.
Thanks, I'm learning.
Old 26th November 2011, 03:09 PM   #6
I found that NE5532 runs at 22v.
This could be a fix for the OpAmp. ?
http://www.datasheetcatalog.org/datasheet/fairchild/NE5532.pdf
Old 26th November 2011, 04:24 PM   #7
OP249
ABSOLUTE MAXIMUM RATINGS
Supply Voltage +/- 18 V
Input Voltage +/- 18 V
Differential Input Voltage 36 V
Voltage Supply Range VS min +/-4.5v typ +/-15v max +/- 18v
So OP249 should be ok.
Old 27th November 2011, 07:37 AM   #8
darkfenriz's Avatar
So-so.
Let's say it's good.
The question is why not us an IC regulator for regular job and something really sophisticated for high quality supply.
I don't see a point in using something this complicated, when its supremacy to say lm317 is questionable.
Old 27th November 2011, 12:57 PM   #9
Hmm, I'll use it as a preregulator for a simple shunt regultor then.
Question: The current 15v version uses 15v and 10v zeners. If i wanted to raise to 18v, appart from upgrading the opamp, the 15v zeners would get changed to 18v, but the 10v one?
Old 27th November 2011, 01:06 PM   #10
The higher voltage regulator uses separate supplies.
+-15Vdc for the opamp.
Rectified and smoothed 18+18Vac for the power input.
The lower voltage regulator uses rectified and smoothed 9+9vac for the opamp and the power input.
Don't get the two regulators mixed up.
Changing to a 40Vdc or 44Vdc opamp is not going to allow your higher voltage regulator to survive 18+18Vac if you omit the separated supplies.
If you keep the separated supplies, then you don't need a higher voltage opamp.
regards Andrew T.
Diode regulator VS IC regulator. Rembrant Power Supplies 5 31st May 2011 03:38 AM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Page generated in 0.12167 seconds (79.25% PHP - 20.75% MySQL) with 11 queries
