Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th December 2011, 05:03 PM   #51
Close rated fusing is 33VA/220Vac ~ T200mA
Normal nuisance resistant direct on line starting fuse rating is 3*33Vac/220Vac ~ T500mA
regards Andrew T.
Old 7th December 2011, 05:35 PM   #52
merlin el mago's Avatar
Thank you Andrew.
Old 8th December 2011, 03:01 AM   #53
carcass is offline carcass  Portugal
not that in this case matters, but its' divided by 230 in Spain
Old 8th December 2011, 09:02 AM   #54
The mains voltage varies from 100Vac+-tolerance to 240Vac+-tolerance around the world.
regards Andrew T.
Old 8th December 2011, 10:26 PM   #55
true, but as I said,nominal European voltage is 230V +- 10% (even though UK uses +10% -6%....so average close to ~240, right Andrew?)...
Tent Labs Heater Supplies (5.5V, 1A) n_maher Swap Meet 4 14th February 2011 11:04 PM
5v to 2.5v for 2a3 filament gasser-dude Tubes / Valves 7 13th February 2010 09:18 AM
Regulated Linear 5V ~1A supply percy Parts 4 22nd April 2009 09:00 AM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Can you make 0-5V DC out of 2.5-0-2.5V AC Ralph Tubes / Valves 17 23rd September 2003 03:20 PM
Page generated in 0.07496 seconds (70.49% PHP - 29.51% MySQL) with 11 queries
