VA assumes resistive load. If you are rectifying and smoothing it you need to take into account RMS current and duty factor. In some cases you could end up back in the same place, but for high duty factor (e.g. Class A amp) you might need to derate by a factor of three or four.
yes, DF,
Many seem to be unaware or forget about the de-rating factor that transformer Manufacturers specify for a capacitor input filter in lieu of resistors passing AC current.
The easiest way I remember the approximate DC current available from a rectified and smoothed supply after applying the de-rating factor is:
Maximum Continuous DC output current = 50% of the rated AC current.
This takes account of the extra resistive heating due to IsquaredR losses being much greater for high crest value currents, cf resistive loaded AC windings.
