Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th November 2011, 06:55 PM   #1
Exclamation car amp problems
hi iv got a fusion 900w amp and it was put in my car and working no problem. then one day it stopped workin all together. cheacked all the wiring and found no fault. amp is powering up but when i checked the subs i found they arnt getting power from the amp, checked amp fuses and all are good. any ideas?
Old 25th November 2011, 09:45 PM   #2
Phildog is offline Phildog  United States
I'd check that the patch cables. I've had this happen to me before when installing Zapco amps. The signal was just too "HOT" and it burned up the patch cables. Do you have another set to use? Also, have you noticed if your amp was running hot? How is the load on it? The impedance on the speakers aren't overworking the amp is it? This will cause clipping...as well as possible permanent damage.
Old 25th November 2011, 11:56 PM   #3
never realy noticed if it wasrunning hot as it wasonly in the car 2 or 3 days. thinking of buying a proper fusion wiring kit to suit the power off the amp, still not sure how this wouldcause it top stop puttin power out to sub....
Help!! New Car Owner - Speaker Problems (No Sound) GhostmanE Car Audio 3 14th August 2008 02:59 PM
Car US AMPS USA-1000x with problems odiepsock Car Audio 3 21st July 2006 03:58 PM
problems with mofset car ampilifier hicksy_5 Solid State 4 13th January 2006 02:52 AM
Noise Problems in Car Head Unit fr0st Digital Source 0 30th September 2004 11:50 AM
Homebrew mobile phone car-kit noise problems andyhomer Car Audio 5 1st May 2003 08:52 PM
Page generated in 0.06479 seconds (78.96% PHP - 21.04% MySQL) with 10 queries
