Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st November 2011, 10:38 PM   #1
Default Secondaries in series - CT?
I have an old HP oscilloscope power transformer with dual 104v secondaries (among others). I intend to wire them in series for 208v. My question is, can the link between the two secondaries be used as a 'centre tap' connection - which I can run to ground? Or would that put me back where I started, i.e., with 104v?
Old 21st November 2011, 10:43 PM   #2
! is offline !  United States
Are they both the same wire gauge? If not, current will be limited by the lesser (higher gauge) of the two.
Yes the link could be a center tap ground, assuming you want +/-104V rails, not a 208V positive rail and ground on the other end of the second winding.
Old 21st November 2011, 11:03 PM   #3
So, a tube rectifier across the series-connected secondaries would yield (roughly) 104V not 208V?
Old 22nd November 2011, 04:13 AM   #4
is this gonna be single rail or dual rail PS?
i guess you are looking for single rail. in that case. it is not a centertap. but a series connection of the 2 sec. and can NOT run it to ground.
if it is dual rail with one rectifier, then run the centertap to ground.
soon to be: papa's Class A all the way
Old 22nd November 2011, 06:59 AM   #5
I was hoping to get around +200vdc (single rail) for a tube circuit, preferably tube rectified. the mains transformer secondaries are 6.3vdc, 6.3vdc, 31vct, 104vdc, 104vdc, 145vdc. the 104vdc secondaries were used to provide a dual-rail supply in an old oscilloscope. i wonder whether wiring the 145vdc and 31vct secondaries in series, instead, would get me in the ballpark of 200vdc?
Old 22nd November 2011, 07:20 AM   #6
you can not use ct's in series. you can however use the 2 104v in series to get 208v (single rail)
but do NOT centertap it to ground. that will be a short.
Old 22nd November 2011, 11:26 AM   #7
All the secondaries should all be isolated from the Primary/ies
Have you checked this thoroughly?
Two isolated secondaries can be connected together. Either in series or in parallel. But, if in parallel then the secondaries must be identical, i.e. exactly the same number of turns.
Once you have a pair of isolated secondaries connected together, you decide which tapping is connected to which reference voltage.
BTW,
secondaries and primaries are rated in Vac not Vdc.
When you rectify and smooth the secondary output the secondary voltage is given very approximately by Vdc ~ sqrt(2) * Vac.
regards Andrew T.
Series wire Antek Secondaries pjanda1 Tubes / Valves 9 20th August 2009 02:17 PM
Need help with dual secondaries in series glt Chip Amps 5 12th November 2007 06:41 AM
12V CT push-pull series secondaries eltonseemann Power Supplies 16 26th July 2007 03:35 PM
is it safe to connect these secondaries in series? jarthel Tubes / Valves 3 15th June 2007 12:28 PM
Yamaha CA-series / CT-series parts DragonMaster Parts 9 19th January 2007 07:48 PM
Page generated in 0.08881 seconds (76.25% PHP - 23.75% MySQL) with 10 queries
