I'm in the process of building an F5 power supply and I have connected the secondaries from the toroid to the rectifiers and and got a low DC reading. My mains are at 122v AC, my secondaries are at 19.3v AC and the DC from the rectifiers (gbpc3506) is at 17.2v DC.
I guess my question is is this the right reading or is this a no load reading? Shouldn't it be about 1.4 times the AC voltage in? All the rectifiers read about the same 4(ea) for monoblocks. One other question: The DC outputs from the rectifiers should be +to V+, - to ground from one rectifier and -to V- and + to ground on the other rectifier... Correct? Thanks in advance. |
#2 |
We need a diagram.
#4 |
Do you have capacitors after the rectifiers yet? If not, add one per power rail and take another voltage measurement, though I agree with DF96 that a schematic would be the most clear way to present the design used.
#5 |
No nothing connect yet, just the rectifiers.
About from the rectifiers to PS board, + to V+ board - to ground PS board / the other rectifier - to V- and + to ground on the PS board. Is that right? |
#6 |
yes, that i right.
soon to be: papa's Class A all the way
#7 |
I never guessed you would be measuring DC with no caps! Now it all makes sense. A full-wave rectified, but unsmoothed, supply has a mean DC value of 90% of the RMS AC input.
#8 |
Before you damage you or your equipment, fit a bulb tester in the mains feed.
If the bulb lights up or glows more than very dimly, you have made a mistake. Every time you modify or add to your wiring/equipment use the bulb tester to prove you have not wired in a fault.
regards Andrew T. |
#9 |
here's a link that works the math and understanding of circuits, great for those in need.
Center-tap Full-wave Rectifier |
| Dumb question? | Phil Olson | Multi-Way | 3 | 23rd October 2009 07:52 PM |
| Simple SE: ???Dumb Tube Rectifier question??? | BillEpstein | Tubes / Valves | 6 | 3rd May 2009 05:52 PM |
| Dumb question, but... | johnm | Tubes / Valves | 3 | 13th June 2008 10:14 PM |
| Dumb question. | G | Tubes / Valves | 2 | 16th January 2008 08:16 PM |
| maybe this is too dumb a question... | dannyspencer | Solid State | 6 | 18th April 2004 04:57 PM |
| Page generated in 0.10746 seconds (77.77% PHP - 22.23% MySQL) with 10 queries |
