Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st December 2011, 11:18 AM   #61
paper will be a source of fuel for burning.
Similarly most varnishes will be fuel for burning.
Adhesives will be a fuel for burning.
Asbestos and glasswool and rockwool and mica have a very high resistance to burning. (I am not suggesting you use any of these, just showing what the difference is when thinking of Fuel).
You must choose carefully to avoid combustion during/after overheating.
BTW,
combustion (or charring) results in carbon residue that is likely to conduct electricity.
Hi temperature Mylar tape (without adhesive) is often used, but difficult to source.
Old 21st December 2011, 12:54 PM   #62
iko is online now iko  Canada
iko's Avatar
Have a look at this page, it has some good info on winding your own transformers, including info about insulating material.
output-trans-winding.html
Old 21st December 2011, 12:55 PM   #63
iko's Avatar
If you're looking for a cheap alternative insulating material you might want to consider the ptfe (teflon) plumbing tape. Of course, proper insulating paper like Nomex is what you should use, but it's very expensive.
Old 21st December 2011, 01:11 PM   #64
jcx is offline jcx  United States
NO!
teflon plumbers tape will "creep", flow under the slightest stress, thinning the insulation to nothing over time - it is NOT a suitable electrical insulator
Old 21st December 2011, 01:16 PM   #65
iko's Avatar
I agree that only proper insulating material should be used.
But I wonder why you say that the teflon tape would thin over time; even if layered thick enough? What kind of stresses would a transformer sustain in use? Just curious what you have in mind, that's all.
Old 21st December 2011, 01:26 PM   #66
the pressure inside a multilayer winding can be huge - each additional layer of wire's winding tension adds to the pressure
then there is also extreme stress concentration when wires cross at angles instead of laying in the layers evenly
teflon in particular embodies the concept of "plastic" to a unintuitive extreme - the molecules are so slippery they will slide past each other on a very long time scale - look up "creep" in plastics
our intuition is more experienced with stuff like mylar that "work hardens" as stretching orients the molecules along the stress axis and they stick together enough to become more resistant to further deformation
teflon basicaly creeps forever
Old 21st December 2011, 01:34 PM   #67
iko's Avatar
Well then, forget considering plumber's teflon tape for use in transformers. Use Nomex.
Old 22nd December 2011, 01:51 AM   #68
JOHN BALI's Avatar
ok, I wil to try find nomex
but if I can't find maybe I will use plumber's teflon tape I have it a lot
I don't know if anyone has really use it before on trafo making, maybe I'll be the one
the point is I must use anything that can resist fire & thin enough to put in
Thanks to all reply
Thank you, I wish you happy
peace & G B U
Old 22nd December 2011, 02:44 AM   #69
Tony is offline Tony  Philippines
Tony's Avatar
i use all of these in my transformer builds....
i use "fishpaper", kraft paper, and many other kinds of papers, i never had a traffo burn out on me......
Old 22nd December 2011, 09:41 AM   #70
JOHN BALI's Avatar
Thanks Tony
I find this paper
Maybe it is can be used...
my mother often use it in the kitchen to make some cake
btw, now is mother's day here in my country
Happy mother's day for my mom
wish you all the best
Then if we make trafo that run cool (below 1T)
why we need so expensive insulator material?
But if we run the trafo more than 1T
that good insulating material must be used
So if I go 0.8-0.9T & I use this paper I guess it just okay
but if not okay please tell me...
The trafo that I made earlier even not using inter layer insulator
peace & G B U
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
Which, Foil Air Core or Iron Core Inductors slhijb Multi-Way 16 20th November 2009 03:12 AM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 01:28 AM
Iron Dust Core Transformer Hemal Car Audio 0 7th June 2004 03:43 PM
Air core vs Iron core Ilianh Multi-Way 5 2nd January 2003 01:36 PM
Copyright ©1999-2013 diyAudio
