Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd November 2011, 02:45 AM   #21
Tony is offline Tony  Philippines
Tony's Avatar
from the available winding area, i allow 80% for copper, 20% for insulation materials....
then from the 80% percent, i allot half of that for primary and the other half for the secondary.....
you choose your wire size this way....even if your formula tells you to use gage 14 say, if space permits, nothing stops you from using #13....
if you can not get the desired wire size fit into the window, then you use the next bigger core size.....
Old 22nd November 2011, 09:43 AM   #22
Originally Posted by Tony View Post
equations are fine, they are mere guides as to how to proceed with traffo buildup....design is iterative process....
bottomline, whatever figure that comes out of the formula does not mean you have to stick to it, it never happens that way in the real world.....
That is simply not true.
There are professional software programs providing you with a complete winding scheme (number of turns, gauges, interleaving thickness a.s.o) given a particular core size and voltage/current requirements, and these programs are accurate (transformers are physical things; you can calculate everything).
I have seen this in the "real world", just a pity that I can't afford something like that (the program I have seen "at work" is actually not for sale but is available on a lease basis).
The fact that we wind our transformers on an iterate basis has more to do with not having this software; the equations I use are perfectly accurate and actually the same as in these software programs. Doing the calculations by hand just takes more time; the outcome however is equally accurate.
Old 22nd November 2011, 10:06 AM   #23
Originally Posted by JOHN BALI View Post
Allowable currents to flow in the copper wire per area (cm²) symbol S
S = 3A to 5A per cm²
for 100VA transformer I use 0.25 to 0.3mm diameter cooper wire for primary (220volt)
3A/sqmm, not 3A/sqcm.
0.3mm diameter and 5A/sqmm gives 353mAac
times 230Vac gives 81VA before accounting for efficiency. I'd guess at ~70 to 75VA for 0.3mm diameter and 5A/sqmm.
0.25mm diameter and 3A/sqmm gives 147mAac
times 230Vac gives 32.4VA. Reduce to ~25VA for output rating.
If my sums are correct then your primary wire looks too thin.
Can someone confirm where I have gone wrong?
Old 22nd November 2011, 11:21 AM   #24
Essentially right.
3A / mm² is for quality transformers, especially when temperature is a factor.
5A / mm² is for economy, where temperature, strayfields are not important.
Primary current is determined by secondary power (load), not by what the core might be able to deliver.
For example when I calculate a transformer which must supply 300 watts of secondary power, and I want B not exceeding 1T, I know a need a "600" watts core because of the larger required winding space. Wire diameter of the primary however can be calculated for 300 watts (no problem with the momentary higher inrush current at start up).
Old 22nd November 2011, 09:08 PM   #25
Tony's Avatar
if i live in your part of the world, then our "real" worlds would have been similar.......
unfortunately, materials available to you is not available to me vis-a-vis cores, you know your core manufacturers, i do not.... you deal with fresh virgin materials, i use scrapped traffos and cores....
i build traffos that work, are not too hot to touch and doesn't burn out in use, i must be doing things right.....
Old 22nd November 2011, 10:12 PM   #26
I understand Tony, of course.
But be it your or my world, the same formulas apply.
Important to know is what core material we deal with; the difference between 0.35 and 0.5 mm is physically obvious. When the laminations show an oxyde coating you can be pretty sure that the material is heat annealed.
So we have already 4 possibilities, covering almost all options.
For these options the important data are easily to find on the www, also for you.
I would not rely on RDH3, 4 or whatever; mostly out of date.
Good luck with your projects.
Old 22nd November 2011, 11:31 PM   #27
alexcp is offline alexcp  United States
alexcp's Avatar
I know I am late for this discussion, but here are the formulas I used back in high school, when quality ready-made toroids were not available. I did design a number of hand made transformers with these formulas, and all worked reliably. These formulas are (1) oversimplified, (2) very conservative, made for poor quality iron, and (3) designed for 50Hz.
Power(W) = (Core-Area)^2; Core-Area is in cm^2
Turns-per-volt = (50..70) / (Core-Area); Core-Area is in cm^2
Primary turns = Primary voltage * Turns-per-volt
Secondary turns = Secondary voltage * Turns-per-volt * 1.2
Wire diameter = 0.7 * sqrt(Current), Current is in Amps
Looks like these are is agreement with the (complicated) formulas above.
Old 23rd November 2011, 07:37 AM   #28
JOHN BALI's Avatar
Yes its should be mm²
but I gonna confused with this image from my real world
no 1 = must be fake, 5A * 64v = 320VA to small for that power
dimension 3" * 2.5" * 1.75" (stack)
primary wire = 0.25mm diameter
secondary wire = 0.7mm diameter
no 2 = maybe its okay, 5A * 64v = 320VA, or maybe 5 * 32 = 160VA?
dimension 3.75" * 3.25" * 2.15"
primary wire = 0.5mm diameter
secondary wire = 1.2mm diameter
no 3 = was used in 30watt amp so its maybe quite good transformer, even the iron core is black in color, anyone know what is this core name?
all trafo for 220 volt ac input
the AWG table make me more confuse, from the shop that I bought wire they ask me in mm diameter not AWG's.
Can anyone show me the right AWG to metric conversion.
then for 0.25mm 0.5mm or 0.7mm diameter how much currents can flow safely?
Please tell me the actual reliable VA for no 1 & 2 ?
so my mind can be clear
I'm also read this
http://www.diyaudio.com/forums/power...ffo-build.html
very good traffo making, but tube is out of my range
Sir Tony, that winding machine is a DIY tool?
so cool
Old 23rd November 2011, 07:46 AM   #29
Google is your friend
Old 23rd November 2011, 08:31 AM   #30
JOHN BALI's Avatar
ok, but sometimes I miss the right choice
too much result
Maybe some experience of winding from you?
I already made some rewinding of trafo EI & toroids too.
some customize too but not sure about it work
not sure the ratting itself
So please give me your secret formula?
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
Which, Foil Air Core or Iron Core Inductors slhijb Multi-Way 16 20th November 2009 03:12 AM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 01:28 AM
Iron Dust Core Transformer Hemal Car Audio 0 7th June 2004 03:43 PM
Air core vs Iron core Ilianh Multi-Way 5 2nd January 2003 01:36 PM
Copyright ©1999-2013 diyAudio
