Iron Core Transformer Formula
Old 5th October 2012, 01:01 AM   #121
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
use whatever is available to you as long as it is thick enough for the job...
as you deviate from the square core cross-section and the more rectangular it becomes, then the mean length per turn becomes longer and with it the resistance of the winding goes up, but this is mitigated somewhat by the fewer turns required with bigger cross-section magnet wire....
use of insulation varnish after the built up traffo is good, the varnish not only insulates the windings but also goes in between the laminates and this reduces eddy currents as well....what i do is to dip the built up traffo into a bath of varnish lifting it up when bubbles dissapear, this is done at least three times.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 5th October 2012, 03:02 AM   #122
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Ok, that great
you just point it out right what I need
now my hesitation has gone...
This time good transformer is the final result
I will built it slowly so the varnish cure & the trafo can be used instantly
Thank you Tony
Thank you, I wish you happy
peace & G B U
Old 5th October 2012, 04:58 AM   #123
donnyab is offline donnyab
tony, the winder you are using on the phils website seems
to be different to the one photographed here. The one here
is better, it seems sturdier ?
Can you remember specifically where you got it ?
How come you don't attach a small motor using gears or something
so it would free up your other hand ?
Old 5th October 2012, 05:47 AM   #124
TonyTecson's Avatar
Originally Posted by JOHN BALI View Post
Ok, that great
Thank you Tony
you can pretest yout finsihed traffo right after completing it to see that all voltages are ok.....and then you can dip the whole thing in varnish....
it is better to wait 3 days if using air drying varnish....
Old 5th October 2012, 05:59 AM   #125
TonyTecson's Avatar
yes, i have 2, one is with a digital/mechanical read-out, but i dumped it because it had a tendency to stop counting in the middle of a winding run.....really annoying...
winders like those are easily available in RAON in Manila for about U$20 you can have one...
i like the dial wheels better, and quite accurate too...the two winders are same size really...
i have plans to motorize it, but too lazy at the moment...
Old 31st December 2012, 06:38 AM   #126
JOHN BALI's Avatar
Hi, It is more than a year...
I don't finnish anything yet, sorry
I hope next year that can be done...
Happy New Year to all people here
hope Goodwill to you
Best Regards
John
peace & G B U
Old 20th April 2016, 01:19 AM   #127
masood is offline masood  India
Hello sir.
As i read or saw the formula of core area=square root of output transformer/5.58 and second formula of core area of transformer=1.152*square root of output power of transformer
Cm.
What is right formula
Old 20th April 2016, 01:30 AM   #128
TonyTecson's Avatar
depends on what you are trying to build, the quality of the core and the working voltages..
https://www.youtube.com/watch?v=s6NyTprQCBI
Old 20th April 2016, 12:54 PM   #129
Sir.i want to make tranfr.230v input.and 65_0_65v ac at 10A using crgo,E I core
What will core area and TPV ,thanking you,
Yours
Old 20th April 2016, 11:55 PM   #130
TonyTecson's Avatar
strudy the video carefully, it has all you will ever need to make your own...
Iron Core Transformer FormulaHide this!Advertise here!
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 09:15 PM
Which, Foil Air Core or Iron Core Inductors slhijb Multi-Way 16 20th November 2009 04:12 AM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 02:28 AM
Iron Dust Core Transformer Hemal Car Audio 0 7th June 2004 04:43 PM
Air core vs Iron core Ilianh Multi-Way 5 2nd January 2003 02:36 PM
Copyright ©1999-2017 diyAudio
