Iron Core Transformer Formula - Page 12 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th October 2012, 08:50 AM   #111
metal's Avatar
Tony is right, look at this page: Jan's transformer article p4
Has excellent advices to follow.
Here is a 4-digit counter that I have recently built, code, eagle files, attiny2313.
metal
Old 4th October 2012, 08:59 AM   #112
TonyTecson's Avatar
this is what i use for mandrels:
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 4th October 2012, 09:04 AM   #113
metal's Avatar
What winding machine do you use?
Old 4th October 2012, 09:11 AM   #114
TonyTecson's Avatar
china job:
Old 4th October 2012, 11:29 AM   #115
sorry for OT but :
google for slup122 and up to slup127
,they are pdf files. first hit.
TI website search engine is shite. could not find opa2134 ...
listen! Can you hear that ...
Old 4th October 2012, 11:29 AM   #116
metal's Avatar
can you give a closer photo for the transformer you are winding? I want to see how the windings look
Old 4th October 2012, 11:42 AM   #117
TonyTecson's Avatar
lots to see here: Tony's Transformer DIY pics
Old 4th October 2012, 11:48 AM   #118
metal's Avatar
If you don't have the core readily made, what material do you use to form it?
Old 4th October 2012, 11:55 AM   #119
TonyTecson's Avatar
plastic premade bobbins are easily available in Manila.....
Old 4th October 2012, 02:11 PM   #120
JOHN BALI's Avatar
Thanks for quick reply from Tony & Metal
Very good suggestion & advice
Now I change my mind
I'm planning to make bigger trafo (about 600VA) but after look at
http://www.diyaudio.com/forums/power...-build-28.html
then more question appear in my head
I will make bobbin for this one but the form is rectangle not square as Tony suggest.
Please tell me what the disadvantages with rectangle shape?
I want trafo that not so high that can be fit in the shorter case
Rectangle because I will use :
1 1/4 inch (32mm) center tongue stacked 6.5 inch (16.5mm)
The thickness of the laminated plate is 0.5mm & I will go bellow 1T
The bobbin I will made with "fiber" PCB
Every 1 stack complete winding, brushed with clear insulating enamel
then I have a choice to use paper or plastic for insulating.
The paper is "brown wrapping paper" &
the plastic is that what use as "laminating paper" it is can stand up to 150C
& I guess its good to be used
but allmost Tony's trafo use paper insulator...
Again please tell me what to use here?
For finishing I'm not dip it into the insulating enamel because the winding is already insulated before & for the laminated plate just do with brush
So I'm on the right track or I must find bigger core size?
Thank you, I wish you happy
peace & G B U
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
Which, Foil Air Core or Iron Core Inductors slhijb Multi-Way 16 20th November 2009 03:12 AM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 01:28 AM
Iron Dust Core Transformer Hemal Car Audio 0 7th June 2004 03:43 PM
Air core vs Iron core Ilianh Multi-Way 5 2nd January 2003 01:36 PM
Copyright 1999-2017 diyAudio
