Iron Core Transformer Formula
Old 5th January 2012, 11:53 AM   #91
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Originally Posted by Tony View Post
the most sensible thing you said so far......
No need to be RUDE. We are only trying to help.
Old 5th January 2012, 11:56 AM   #92
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
oh...not meant to sound that way.....it is just that, if you are not building any transformers, then these theories will be very hard to digest.......just trying to help......
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 5th January 2012, 12:08 PM   #93
We are taught these theories at Uni. And, funnily enough they work. The Economists and Cheap manufacturers will always try to cut corners.
Why do you think that mains transformers in Mass Produced goods often fail.
It's down to the money counters trying to make things as cheap as possible.
In the DIY World we are trying to better them.
I recently disassembled a Far Eastern Electric Typewriter that had a failed mains transformer. Reverse engineering the maths the manufacturer was using over 3200mT as the magnetising flux on a cheap transformer. It was designed to NOT last.
Old 5th January 2012, 12:15 PM   #94
TonyTecson's Avatar
i build my traffos to run cool to touch.....
i run them at less than 0.9T and in some cases even down to 0.6T.....
diy'ers are not motivated by profit, we build them to our liking based on some needs.....
Old 5th January 2012, 12:17 PM   #95
Exactly, that is why I recommend 780mT.
780mT is what is used in the MoD for long term reliability.
900mT is not too different and is well below the magnetic saturation level of the core.
Old 5th January 2012, 12:43 PM   #96
iko is offline iko  Canada
iko's Avatar
Originally Posted by KatieandDad View Post
Where W is 110% of the TOTAL secondary power
K = 0.0086 for EI, 0.015 for TU and 0.035 for Ferrite type A13
What would K be for C-core or double C-core?
Old 5th January 2012, 12:44 PM   #97
You'd need to ask the manufacturer. I left uni over 30 years ago.
Old 5th January 2012, 01:13 PM   #98
iko's Avatar
As far as power transformer design goes, here's my contribution. This file will be there for the next few days, then I'm going to remove it.
Old 6th January 2012, 05:37 AM   #99
dtproff is offline dtproff  United States
Here is a PDF of the MathCAD file I used for AC/AC transformers. In this example it is for a 10W.
Tony
File Type: pdf Mathcad - Linear 50-60Hz Transformer.pdf (70.4 KB, 93 views)
Old 3rd October 2012, 06:05 AM   #100
rikkitikkitavi is offline rikkitikkitavi
Not in a single post, no. And not when you are shouting.
I would say look up SLUP121-127.pdf (filename) from Texas instrument , a collection of application notes which summarises the design of a ferrite switching transformer quite well.
When you understand the theory, then the formulas are quite easy.
Remember that a ferrite core switching transformer is limited both by saturation and losses.
listen! Can you hear that ...
Iron Core Transformer FormulaHide this!Advertise here!
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
Which, Foil Air Core or Iron Core Inductors slhijb Multi-Way 16 20th November 2009 03:12 AM
Solen Air core inductors, Hammond Iron core. gnomus Swap Meet 0 30th July 2004 01:28 AM
Iron Dust Core Transformer Hemal Car Audio 0 7th June 2004 03:43 PM
Air core vs Iron core Ilianh Multi-Way 5 2nd January 2003 01:36 PM
