Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th November 2011, 10:38 PM   #1
Default Power supply with forced symmetry
Hi!
Is it better to have independently regulated positive and negative voltage rails, or something like this schematic, to always keep voltage symmetric by decreasing voltage on less loaded side?
I am trying to design custom voltage regulator and protection for power amplifier (this is a extracted and simplified part of regulator circuit), and this looks interesting but I'm not sure is this concept actualy a good idea for audio amplifier?
P.S. Sorry for my bad English
Old 22nd November 2011, 08:24 PM   #2
twest820's Avatar
When I looked at servoing ground in an amp I was fooling around with a while back I concluded it wasn't worth the hassle; no real gain to forcing symmetry in a linear supply as most amplifiers have no signifiant error terms which would benefit from cancellation by symmetric movement of the rails.
For switchmode I found there may be some benefit depending on the control loop gain, supply structure, switching frequency, SMPS topology, and noise injection points. But that's a separate discussion.
Old 22nd November 2011, 08:31 PM   #3
There may be an advantage to not having matching rail voltages. Depends on the circuitry and how it handles zero crossings.
Old 22nd November 2011, 08:47 PM   #4
twest820's Avatar
True. Though, personally, I've yet to find an application where class XD operation is compelling.
Old 22nd November 2011, 09:01 PM   #5
Hi, Generally forced symmetry has no advantages whatsoever, rgds, sreten.
In some cases you make the ripple on one rail lower (asymmetrical) to match
the assymetrical PSRR of the power amplifier circuit, depends on the circuit,
and for what stage you are manipulating the intrinsic ripple.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 23rd November 2011, 07:07 AM   #6
Thanks!
Now I know why everybody is going to Class D - When will Nelson be forced? coloradosound Pass Labs 88 6th December 2009 08:07 AM
forced aircooling makeb4break Tubes / Valves 40 11th February 2009 02:58 AM
Very large forced air heatsink for sale mpmarino Swap Meet 5 27th November 2007 02:05 AM
FS: Forced cooling tunnel webercarbmann Swap Meet 0 27th November 2002 08:50 PM
Page generated in 0.08728 seconds (70.26% PHP - 29.74% MySQL) with 11 queries
