Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th November 2011, 12:07 PM   #1
lloop9 is offline lloop9  Singapore
Default Question about clamping diode...
Hiya fellows, I was thinking of buying this ebay regulated PSU.
I read that it would be prudent to use clamping diodes on the output to prevent damage from reverse polarity spike. I need advice if installing the diodes before the 0.1uF bypass caps is correct? Can I use the 1N4004?
linky: +/- 1.5 to 32V DC Adjustable Voltage Regulator Module. Based on LM317/LM337 | eBay
cheers
Old 18th November 2011, 12:34 PM   #2
KatieandDad's Avatar
D5, 6, 7 and 8 already provide protection against reverse polarity at the output.
You dont need the extra diodes.
Old 18th November 2011, 10:35 PM   #3
DF96 is offline DF96  England
D5 and D6 prevent back-current through the regulator. They do not stop reverse voltage spikes. D7 (D8) might help if C5 (C6) is big enough.
Old 18th November 2011, 11:21 PM   #4
Hi, C5(C6) is 10uF. I believe clamping diodes across C7(C8) will help prevent reverse V spike but I could be wrong...
cheers
Old 19th November 2011, 01:15 PM   #5
It all depends on what is producing the reverse spikes and how big they will be.
Old 19th November 2011, 01:24 PM   #6
nattawa is offline nattawa  Canada
The clamping diodes are there to discharge C5 and C6 at power turn off. Without them the adjustment terminal of the regulator may stay at a higher potential than that of the input and output terminals for a while, and the charge in C5 and C6 may or may not damage the IC.
Old 19th November 2011, 06:37 PM   #7
jitter is offline jitter  Netherlands
jitter's Avatar
My personal opinion is that the psu "as is" is fine. Only if I were expecting reverse polarity spikes would I consider using the extra diodes on the output, not 1N4004 but a type specifically meant for transient suppression, like 1.5KE.
diode question mike49504 Car Audio 2 17th January 2010 02:28 AM
Disk Clamping - Which is best ?? poynton Digital Source 32 1st January 2010 04:57 PM
Gluing and Clamping wintermute Construction Tips 6 25th August 2009 03:09 AM
Diode Question betelgeuse Parts 4 14th December 2008 10:40 PM
Diode Question TunaFish Tubes / Valves 8 13th October 2003 11:53 AM
Page generated in 0.09847 seconds (77.18% PHP - 22.82% MySQL) with 10 queries
