#11 | |
#12 | |
On a battery the value of the bypass cap hardly matters, small is good 0.1 or 0.01uf is fine. You can buy a power supply PCB in ebay for about $5 Read the data sheet for the LM7805 and if you don't understand it buy the PCB. There are many on eBay, see this item for one example: 120748494865 |
#13 |
Thanks for all the help and for tolerating my ignorance--I'm learning though thanks!
Looking at the schematic I beleive those are non polarized capacitors because of the 2 parallel lines for the cap schematic symbol. So I guess I'll get ceramic disc caps. I don't understand what the dot is for in the symbol though on the voltage input and the two dots on the output cap. |
#14 | |
#15 |
Picked up a LM7805, along with .1 uF cap for output power, from Radio Shack the other day. (I have yet still to pick up a .33 uF cap for input power since radio shack doesn't stock this cap--don't know how much this will help the sound.)
Powering the FIIO D3 with it. It sounds better than the stock switching power supply. Switching back and forth in A/B tests, the LM7805 (along with the $28 13.8V Pyramid 3A regulated power supply feeding it) has more clarity, separation--less muddiness. Now I have to go through my entire collection again as some albums that didn't sound that good before, sound great--pretty cool. Btw, just today I noticed I had an LM317T on a board I harvested from today. I think I'll try out this regulator and A/B it to the LM7805. |
#16 |
Try reading this article on 24V supplies if you want the best, will need a few more part, but may be worth it for a DAC depending on your amp & speakers.24-Volt Aikido Amplifier with the 6GM8 & Aikido hybrid power amplifiers
#17 | |
![]() Behringer A-500 (tweaked a lil) + Infinity RS 2001 is what I have. Btw I accidently blew my tweeters today and got replacements out of Infinity SM-62 I picked up locally from Craigslist for $40. Sounds the same if not slightly crisper/better. I did notice the crossover board & components of the SM-62 were about 1/5th the size of the crossover in the RS-2001--no wonder the RS-2001 sounds so much better not to mention larger cabinet. These RS 2001 speakers are pretty darn nice! Last edited by audiogeekess; 7th December 2011 at 08:41 AM. |
| 12V AC adapter to 5V | BubbaGump | Power Supplies | 5 | 28th October 2010 06:26 PM |
| 5V out of 12V regulated | DECKY999 | Power Supplies | 0 | 7th April 2008 05:37 AM |
| 12V to 5V | dome406 | Parts | 8 | 2nd May 2007 07:47 AM |
| Stepping 12v down to 5v | silentblackhat | Solid State | 10 | 22nd February 2006 09:43 PM |
| Page generated in 0.10042 seconds (78.96% PHP - 21.04% MySQL) with 10 queries |
