I am adding a subwoofer amp and SMPS into my all-in-one switch/dsp/amp and have a small problem. I have no choice but to place the SMPS right next to the inputs. I'm using the SMPS500R from Connexelectronic, which has a very high frequency, so will I ever notice noise or interference from it? If so, would building a small faraday cage around it work to isolate it from the low voltage input signals (I'm worried the SMPS will interfere with the inputs, not the other way around). The amp will be underneath the bundle of input wires and the SMPS will behind the minidsp's and in front of the speakon connectors (up is rear in the picture).
#2 |
Anyone?
#3 |
Putting a shield around the SMPS obviously won't harm the input signals. Make sure the SMPS doesn't get too hot, though...
I can't help but think that cleaning up the mess of wires in your amp will also be beneficial. I'd use shielded wires for the low level signals. And what's up with the puny wires on the mains entrance? I'd use at least 0,75 mm2 (~ 19 AWG) in the correct colour coding with shrink tube on the exposed parts... Last edited by jitter; 19th November 2011 at 06:06 PM. |
#4 |
yea, that is a wire mess... good antennas
#5 |
Putting any signal or power wire close to their respective returns, possibly twisting them in pairs is much more efficient
| Isolate the audio input | lindomar | Class D | 10 | 29th December 2010 11:17 AM |
| How to measure Common Mode Signals in the input stage? | Pippi Lindenstroem | Solid State | 4 | 16th October 2009 03:36 AM |
| how to isolate input ground? | Zero Cool | Solid State | 0 | 17th December 2006 10:11 PM |
| How do I connecting speaker signals to line level input ? | ANALOG GUY | Car Audio | 1 | 17th April 2006 07:42 AM |
| Input signals and my amp | RMS | Tubes / Valves | 6 | 19th July 2002 08:42 PM |
| Page generated in 0.08534 seconds (71.08% PHP - 28.92% MySQL) with 10 queries |
