On/Off switch using momentary push button
Old 10th November 2011, 09:09 AM   #1
polsol is offline polsol  South Africa
Default On/Off switch using momentary push button
I am in the midst of designing something of a 'universal power supply' for audio power amplifiers in a seperate enclosure.
Most electronics these days seem to incorporate a 'push on, push off' momentary switch design rather than a latching switch.
Any references of how to design this?
The switch I am considering using (latching) is a 3 amp/250V coupled to a 300 VA 25-0-25 torroidal. However, would prefer the 'push on, push off' scenario. I guess there should be no problem with the latching switch handling the 1.25 Amps @ 240V nominal current but am a little concerned about surge currents at switch on so using a relay might be the better option - I mention this as possibly a relay would be an integral part of the first question requirements.
Your thoughts would be appreciated.
Tony M
Old 10th November 2011, 09:43 AM   #2
DF96 is offline DF96  England
You can get mechanical switches which incorporate a 'push to change state' operation, but whether these are available in panel mounting form I don't know. Single-pole versions are sometimes used for lighting, but you really need double-pole for safety. You basically need a flip-flop. The advantage of doing this mechanically is that Off really does mean Off; an electrical flip-flop needs a power supply.
Personally I prefer the certainty of a proper toggle-type switch, whatever external shape it has.
Old 10th November 2011, 01:06 PM   #3
lcsaszar is offline lcsaszar  Hungary
I use a RAFI illuminated panel mount switch for exactly the same purpose on my preamplifier.
Old 10th November 2011, 04:59 PM   #4
R.I.P.
Use relays to achieve the latch ON latch OFF action.
There are circuits on the Forum.
I seem to recall they use three ordinary (cheap) relays to achieve latching with a momentary contact switch.
All the switching and relays can use low voltage DC with just the final Mains relay at high voltage.
Is this the mechanical equivalent of a bi-stable?
regards Andrew T.
Old 10th November 2011, 05:09 PM   #5
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
A latching relay would work a charm. Too bad they're so expensive.
Old 11th November 2011, 05:12 AM   #6
Thanks all for the input.
Ultimately I guess it's easier just to use a DPST pushbutton so will order a Schurter MSM 19 LA. Bit of an overkill - and expensive - but it does handle 12A @ 250V on the contacts.
Just rather keep to the KISS principle and avoid over complexity.
Tony M
Old 11th November 2011, 05:40 AM   #7
CBS240 is offline CBS240  United States
CBS240's Avatar
Along with the flip flop you need to be sure it is de-bounce or you have to add a small cap across the switch. A one shot can be an advantage. But then you have more complexity. But then it is easier to interface protection detection circuits for auto shut-down.
All the trouble I've ever been in started out as fun......
Old 11th November 2011, 08:20 AM   #8
Elvee is offline Elvee  Belgium
Elvee's Avatar
This circuit includes the debouncing, and you can make make six of them out of a single IC.
It was made for automotive applications, but can work from 3 to 15V if you remove the supply filter.
You can use a smaller MOS or a bjt to drive a relay.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 11th November 2011, 08:25 AM   #9
Boscoe is offline Boscoe  United Kingdom
Jk flip-flop also works well driving a relay, your momentry button has to be two way though as you need to send the input high then down to ground.
Audio projects and more: gswdh.co.uk
Old 15th November 2011, 08:22 PM   #10
TechGuy is offline TechGuy  United States
Perhaps you're looking for something like this (using D Flip-Flop)
Single-Pushbutton ON/OFF Power Control - Maxim
other debouncing circuits using logic gates.
Switch Debouncing - The Lab Book Pages
You also need an High side mosfet driver with built in charge pump to retain the boostrap voltage. Something like this:
LM9061 - Power MOSFET Driver with Lossless Protection
You'll need a small aux DC power supply to power the logic gates and high side driver.
A small saturable inductor could be used in serious with the high side switch mosfet to limit initial current rush. Alternative you could couple the power switch with AC zero crossing so that the mosfet only turns on just after the zero crossing for a slow start. Or you can use a high value gate resistor (perhaps 100 to 1K ohms) but use a parallel diode to speed up gate turn off.
On/Off switch using momentary push buttonHide this!Advertise here!
Push button power On/Off switch for a 10 mm front panel NicMac Parts 7 22nd February 2010 08:24 PM
What type of momentary switch Nordic Parts 1 8th October 2006 09:47 AM
Momentary Switch mourip Parts 11 26th June 2006 09:53 PM
Need help finding push button power switch to fit my amp Ken C Solid State 4 12th July 2004 11:42 PM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
