Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st November 2011, 06:40 PM   #1
pdul is offline pdul  Denmark
Default Audiotek Cutie mini regulator
I finally found my original paperwork that came with the kit from Audiotek.
Hope that those of you who got stranded with a kit without documentation
will have use of this, since it seems impossiple to connect to diyzone to fetch it.
Old 1st November 2011, 08:20 PM   #2
I have build it in the 15v version, and with 16-0-16v ac it gives +14,99 -15,02v out. Haven`t tested it with load yet, I have to heatsink the transistors first. So far it seems ok
Old 8th November 2011, 02:18 AM   #3
Wolfsin is offline Wolfsin  United States
Both 15 and 18 volt versions work well unless shorted to the case :-( A 15-0-15 transformer allows it to run at 18 volts without overheating. Am curious what the ideal ac-0-ac would be for 15 volts.
'gardz, Dick
Old 8th November 2011, 06:49 AM   #4
Yea! Not much information on the ideal vdrop.
What do you mean by "Shorting to the case"?
Old 8th November 2011, 06:56 AM   #5
My plan is to use it for a preamp. Linestage + Phonostage. Not a blue smoke generator
Old 8th November 2011, 12:07 PM   #6
My plan did not include blue smoke. That was aside effect of trying to fit it into a tiny case. I think I have replaced the damaged components but have not had the courage to "fire it up"
'gardz, Dick
Old 8th November 2011, 08:22 PM   #7
Regarding ideal ac-in for dc-out of 15v does depend on transformer sag and load current so I guess it izHard to fault diyzone's prescience. Perhaps another user running, say, 250ma on each rail, might advise.
'gardz, Dick
Old 13th November 2011, 05:29 PM   #8
Default Testing
Feeling courageous. No smoke
Old 13th November 2011, 07:08 PM   #9
Old 11th December 2011, 05:49 PM   #10
Default A rose iza rose . . .
A somewhat later version of the cutie, a.k.a. qmini, qtmini, gold reference and doubtless other names, is still in production. The hints on current and voltage adjustments might prove useful.
GOLD Reference Mini Regulator
A Mini Power Regulator Replacement gijoe_22 Vendor's Bazaar 0 11th August 2009 03:35 PM
AudioTek Q10 Mini Integrated Amp tvr2500m Solid State 0 27th February 2009 01:21 PM
Page generated in 0.08562 seconds (83.21% PHP - 16.79% MySQL) with 11 queries
