Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th October 2011, 09:07 AM   #1
6unico is offline 6unico  Italy
Default Resistor 4R7 / W5
Hello, i have to change a resistor in a PSU of an Crest 8002 PRO Amplifier and the resistor in the scheme has the value 4R7/W5. What does the W5 mean? I dont think its 5Watt because the space is to small for a Ceramic resistor. Does it mean 0,5Watt?
Thanks for help!
Old 28th October 2011, 09:21 AM   #2
What is the physical size of the resistor you are replacing.This may give you a clue. And IMHO if the resistor is faulty there is a good chance somthing besides the resistor is at fault.
Old 28th October 2011, 09:35 AM   #3
often in electronics we use the descriptor as the decimal separator. eg. 9r1, 1W5, 0k22 etc.
0W5 would certainly be half a Watt.
W5 does not meet any standard that I know of.
I suspect it is bad use of 0W5, but the leading zero has been omitted.
As you can see from the confusion caused, it is far better to stick to the standard of "Never Omit the Leading Zero".
regards Andrew T.
Old 28th October 2011, 09:41 AM   #4
Hi Andrew nice to see you have used your feeding spoon today!!
Old 28th October 2011, 11:18 AM   #5
Thanks to all! @madtecchy of course i've changed all other burned components (MosFet, 2 diodes and one more resistor).
W5-1611sa Jeb-D. Full Range 63 7th January 2012 11:48 AM
WTB: TB W5-704D ernperkins Swap Meet 1 27th August 2011 04:27 PM
BVR for TB W5-1611? chazdrumzalot Full Range 8 22nd April 2011 04:16 PM
Subwoofer with TB W5-1685 clrs Subwoofers 4 20th December 2010 05:22 PM
Page generated in 0.07520 seconds (71.92% PHP - 28.08% MySQL) with 10 queries
