Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th October 2011, 12:40 AM   #1
henryp is offline henryp  United States
Default info on dynaco st-70 ps choke
I have a new choke that is used in a dynaco st-70 and want to use it in a 300b
type amp. Does anyone know the current handling and henries of this choke?
thanks phh
Old 26th October 2011, 01:07 AM   #2
zigzagflux's Avatar
1.5 H, 55 ohm, and 200 mA rated.
Old 26th October 2011, 04:58 AM   #3
This is the Hammond equivalent.
Hammond Choke 156R
Old 26th October 2011, 05:03 PM   #4
thanks phh
Thanks folks for the info. I guess I need to look for something else with more
inductance.
Old 30th October 2011, 02:38 AM   #5
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
this choke is made out of 5/8inch square bobbins, using #30 magnet wire, it is easy to wind one, just fill up the bobbin, you can also layer wind if your wish, me i just scramble wind the thing....just buttend joint the E's and I's......using a thin sheet of paper between the E-I's lowers inductance a bit but gives better current handling....
if you want more inductance, you can use 3/4inch or even 7/8inch square bobbins using a #29 wire.....
preamp suitable for Dynaco st-70- OTHER than dynaco namatjira Tubes / Valves 3 22nd December 2011 01:21 AM
Dynaco ST-70 with a GSI board, Parts diagram and any info PLEASE Tanner Tubes / Valves 9 18th November 2009 10:53 AM
dynaco st 70 c3 dcb50 Introductions 1 30th September 2008 11:20 PM
Dynaco st-70 for sale dcameron Swap Meet 0 4th October 2003 12:08 AM
Dynaco st-70 toenail Tubes / Valves 9 19th April 2003 11:08 AM
Page generated in 0.08566 seconds (73.31% PHP - 26.69% MySQL) with 10 queries
