Hi
I am looking to put together an online power supply using a PFC and Buck Regulator with 1000W+ output. A Google search will turn up PFC/PWM off-line combo controllers, using forward or flyback for isolation, which limits the power output to a few hundred watts. I found this paper from 1998 that discusses a PFC Buck regulator combo: SINGLE PHASE POWER FACTOR CORRECTION CIRCUIT WITH WIDE OUTPUT VOLTAGE RANGE http://scholar.lib.vt.edu/theses/pub...erials/etd.pdf But I was hoping that someone developed a controller implemented this method, But I have not found anything. I suspect there isn't a controller available yet. Thanks |
#2 |
i saw the schem on page 15 of your attachment.
its going to be expensive to drive that high side fet.....probably not worthwhile. For 1000W continuous output power, your best bet is to go for a Continuous mode boost PFC , followed by a Full bridge converter or a phase shift full bridge converter. ....you may need to make the pfc a dual phase boost pfc, to keep individual fet dissipation low. And realistically speaking, at 1000W, your going to need fans blowing over the fet heatsinks. ...and the boost pfc diode is going to dissipate a lot too, so fans on its heatsink. i saw the sepic on page 32....looks good but realistically that sepic capacitor is going to be very big and very stressed. |
#3 | ||
Why do you say "expensive to drive that high side fet"? An H-bridge uses two high side transistors. Buck Regulators are typically 95% efficient. Quote:
The disadvantage is its not isolated and the regulation would not be as tight since a continuous PFC boost would charge the caps a higher voltage, providing more ride-through energy to be consumed near the AC Zero crossing point. Am I missing something else? The author also dismissed sepic as an option. |
| 1kW PFC-Boost | ChocoHolic | Power Supplies | 75 | 23rd May 2011 07:55 AM |
| May I mark this buck, already with PFC, or not? | ontoaba | Power Supplies | 1 | 22nd February 2011 12:36 AM |
| Buck boost regulator | TUBESMAN | Power Supplies | 0 | 21st January 2008 04:04 AM |
| buck regulator | jamesrnz | Power Supplies | 13 | 11th June 2007 06:12 PM |
| Buck & boost transformer | Ilianh | Parts | 1 | 15th March 2004 06:03 AM |
| Page generated in 0.09014 seconds (74.27% PHP - 25.73% MySQL) with 10 queries |
