I am new to the DIY audio.I am starting with my first amp, which is gainclone based on lm-3886.I wanted to know advantages of using toroidal transformer over sheilded EI type transformer.I am a student on budget and need help whether its worth the extra $$ for the toroid?
Also can some suggest good quality filter caps from Panasonic and Nichion as these two brands are easily available in my city. |
#2 |
If rated appropriately the EI type has a lot going for it. I would be happy using one in a Gainclone.
As to the caps, you will be looking at 3300 uf to around 6800 uf for the main reservoir caps at a voltage to suit your supply so realistically you are looking at 63 volt caps. If you can get these in genuine Panasonic or Nichicon then you won't go far wrong.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
A shielded EI core is preferred as torroid has a wide AC bandwith and will pass a lot of AC line garbage into the amplifier
#4 |
Thread from 2003 toroid vs EI type
Transformer: Toroid vs E-I And a good article. http://www.soundstage.com/maxdb/maxdb071998.htm Last edited by RJM1; 27th October 2011 at 06:06 AM. |
#5 |
one problem that can happen with any kind of transformer is if it is operated near it's rated power handling capacity then the core material can become saturated at the current peaks. that will cause a much bigger magnetic field outside of the transformer which can induce noise in nearby circuits. avoid this by using a "overspec'ed" transformer - rated for higher power than needed for your application.
also, in the thread RJM1 linked above, there was alot of talk about shielding. a copper shield will do nothing to contain magnetic flux from the transformer. ferrous material is needed for a magnetic shield, like mu-metal. copper shielding will only help with something like transient noise in switchmode power supply or RF. as for caps, when I use electrolytics I always choose caps rated for 105degrees (centigrade) instead of 85degrees because the 105degree caps will last longer. -Joel |
#6 |
Transformer saturation
“It is important to realize that the saturation problem is a function of the applied voltage and frequency only. It is NOT caused by the amount of current drawn from the secondary winding.” Understanding Transformers: Characteristics and Limitations This is why when you rewind a microwave oven transformer you have to add more turns to the primary winding to avoid core saturation at low power levels. At continuous high power levels the voltage drop across the primary winding prevents saturation. You are right about the copper shield not shielding magnetic fields with an EI transformer, but you can mount the transformer so that the coil sides point up and down so that the escaping magnetic fields go vertically and not into your circuit. |
| DIY Audio Alchemy Power Station 2 Power supply PSU with case | roscoeiii | Swap Meet | 2 | 29th May 2010 06:51 PM |
| Simple Power Supply for Audio Amplifiers. (Why? This is for audio) | AP2 | Power Supplies | 10 | 30th March 2010 12:02 AM |
| voltage on the 1st cap of the aleph-p 1.7 power supply | jarthel | Pass Labs | 15 | 23rd October 2007 09:10 AM |
| Can i use a computer power supply to power audio amplifiers? | destroyer X | Solid State | 91 | 25th September 2006 04:36 AM |
| Page generated in 0.09834 seconds (72.51% PHP - 27.49% MySQL) with 10 queries |
