Best way to create a dual supply
Old 22nd October 2011, 04:12 PM   #1
jtavrisov is offline jtavrisov
Default Best way to create a dual supply
I've been doing alot of research into creating a bi-polar supply from a single one and ran into quite alot of options. I have one extra requirement, the load will not be balanced across the supply. The dual supply will be powering a headphone amp but the positive rail will also be used to power a microcontroller.
My first design failed because I didnt consider this, the rails became very unbalanced with the extra load.
So I need a design that will source enough current and is immune to loading effects (op amp buffer?). At this point I'd like to use a single AC-AC wallwart rather than a chassis mount transformer. The only way I would consider a transformer is if its a small board mount. It's a headphone amp, I cant have it take up a crazy amount of space.
Thanks for any ideas
Old 22nd October 2011, 04:28 PM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
If there is a constant asymetry, you can use a standard voltage regulator to create the virtual 0.
See an example adapted to your situation:
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 22nd October 2011, 04:50 PM   #3
R.I.P.
All the best ideas are simple.
Thanks for that Elvee.
regards Andrew T.
Old 22nd October 2011, 05:10 PM   #4
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
Or use a rail splitter http://docs-europe.electrocomponents...6b800b853b.pdf
and a separate 7905 for the micro-controller.
vac
All atoms to the left!
Old 22nd October 2011, 05:24 PM   #5
knutn is offline knutn  Norway
You could use a voltage doubler. Then you can use a single AC-AC wallwart. And an asymmetric load is not a problem.
Old 23rd October 2011, 04:51 AM   #6
sawreyrw is offline sawreyrw  United States
knutn,
This will work, but delete C1.
Old 23rd October 2011, 01:44 PM   #7
Sorry, it was an error in the schematic. Attached is the correct one with 12V AC input as an example.
Old 23rd October 2011, 04:19 PM   #8
vacuphile's Avatar
C1 still better be removed. What would be it's function?
Old 23rd October 2011, 05:58 PM   #9
C1 is optional - for noise filtering.
Old 24th October 2011, 02:44 PM   #10
amptramp is offline amptramp  Canada
If you are looking to get a solid half-voltage split, use an LM386 with the inputs left open. The output is automatically biased halfway between the positive and negative supplies and, being a power amp, the current capability is pretty good.
Best way to create a dual supplyHide this!Advertise here!
Symmetric supply or dual supply? JWFokker Parts 32 11th August 2011 08:29 PM
10 W Class AB amp: Adapting Single Supply to Dual Supply jonatmudd Solid State 13 18th March 2011 07:02 PM
Dual supply for LM1875 split supply dovganj Power Supplies 30 6th November 2009 03:19 AM
Dual supply... slideman82 Tubes / Valves 12 7th February 2009 11:25 PM
A simple way to create dual(or more!) rotary switches out of single rotary switches stappvargen Pass Labs 14 16th April 2004 11:33 PM
