Hello,
Is there any company, anywhere in the world, that can provide us with Bode Plots for the SMPS Feedback loop if we send them our SMPS schematic and the specification to which the SMPS is intended.? |
#2 |
I am not a company, but can do it for you.
#3 |
Linear Technology (free) Ltspice and very long sim times can be used, with some difficulty since they dropped their BodeCad sw
Ridley Engineering does it in hardware - I haven't used it but the site looks like it has lots of solid info on sw mode |
#4 |
As far as i see, LTSpice doesnt have voltage mode full-bridge pwm controllers, so i wouldnt be able to put many of our schematics in there. I have previously used LTSpice to get individual points on the Gain and phase plots......but it would be very time consuming to get enough points for a whole plot. I have the book by Basso that gives transfer functions for certain standard TL431/Opto feedback circuits, but many of our schematics dont use those standard types, because of eg high, split output voltages such as +/-50V. |
#5 |
Every PWM modulator has its well defined gain.
It is easy to simulate that as a linear gain and perform an AC sweep. |
#6 |
fine for well defined operating conditions - not so much for transition to discontinuous mode, inductor saturation, hard nonlinearities that may give sub-harmonic or other decidedly nonlinear behaviors
but by all means if your circuit can be modeled simiply with state space averaging do that 1st Ltspice does use encrypted models of their own Sw Reg parts but if you have a Spice model for your part it can be ran in Ltspice I have used VBA to extract numbers from a Ltspice log file - use the .meas commands in Ltspice ran stepped sims overnight to obtain points for a graph |
| feedback loop | rmenger | Instruments and Amps | 4 | 21st October 2006 07:04 PM |
| Electrolytic in the feedback loop | yup | Tubes / Valves | 30 | 9th September 2006 07:56 PM |
| feedback loop | rmenger | Parts | 0 | 29th July 2004 01:24 PM |
| Resistor value in the feedback loop | FredG | Chip Amps | 12 | 6th February 2004 08:08 PM |
| Feedback Loop help | KevinLee | Solid State | 4 | 1st December 2002 01:39 AM |
| Page generated in 0.08678 seconds (72.29% PHP - 27.71% MySQL) with 10 queries |
