Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th October 2011, 10:14 PM   #1
Smile duel toroidal transformer on mains
do i just wire all the legs (4of them) together then connect one of them to mains + same with - or am i missing something ? theres a serous lack of info on toroid transformers on the web its probably the most lacking thing i have ever tried to search for.
Old 19th October 2011, 11:09 PM   #2
stop and think.
A dual primary transformer has two primaries.
What are the ratings of your two primaries?
regards Andrew T.
Old 19th October 2011, 11:13 PM   #3
sofaspud's Avatar
Do you have a datasheet for the traffo? It's likely made for 110 or 220 VAC, parallel or series respectively. For US 110V you'd want the primaries in parallel and in phase. "Wire all the legs (4of them) together then connect one of them" doesn't really make any sense.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 19th October 2011, 11:31 PM   #4
http://www.antekinc.com/pdf/AN-4445.pdf
i have 2 that are similar to that same wiring.
what i meant by stick them together is run them in parallel.
i was pretty much just meaning to say that is it any different when wiring two transformers instead of just one.
Old 19th October 2011, 11:32 PM   #5
Originally Posted by AndrewT View Post
stop and think.
not 2 sets of primaries
2 transformers with 2 sets of primaries.
Old 19th October 2011, 11:34 PM   #6
Atilla is offline Atilla  Norway
Soldering Gun Fanatic
There should be a pretty picture with description of which wires go where. Ask whoever you bought it from for the wiring diagram and people will figure it out.
Old 19th October 2011, 11:47 PM   #7
sofaspud's Avatar
Yes, all 4 primaries would be connected in parallel. Use the diagram from the datasheet.
Old 20th October 2011, 09:41 AM   #8
start with just one transformer.
Attach ONE primary to the mains. Power it up through the bulb tester. Did the bulb go OFF?
If correctly wired, then measure the voltages of the other windings. The other primary should have exactly the same voltage as the mains supply.
Disconnect from the mains.
Add the second primary to the first pair of connections. Power up via the bulb tester. Is it OK. Test the voltages. disconnect from the mains
Do you see the pattern developing?
Now add the third primary TEST. Add the fourth Primary TEST.
This way you have no damaging blow ups.
You have no blown fuses.
You have not had to go and reset the mains MCB.
You have survived what is potentially a very dangerous learning experience.
regards Andrew T.
Old 20th October 2011, 09:58 AM   #9
sofaspud's Avatar
Attach ONE primary to the mains... If correctly wired...
And if it's incorrectly wired, stick to battery-powered DC.
Old 20th October 2011, 12:47 PM   #10
DF96 is online now DF96  England
The web has lots of information on mains transformers. However, this is one of the areas of DIY where mistakes can be expensive and, sometimes, fatal. If you are not sure, don't do it. Use a lamp limiter.
Duel Rectifier Issue mark02131 Power Supplies 3 22nd December 2009 02:01 PM
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
No mains transformer B+ ? Salas Tubes / Valves 9 14th March 2007 11:04 AM
how to swich toroidal to mains, HELP juanito Chip Amps 5 21st January 2007 06:24 PM
Toroidal mains transformer bigwill Planars & Exotics 6 29th March 2006 08:18 PM
Page generated in 0.10508 seconds (78.71% PHP - 21.29% MySQL) with 10 queries
