Hi to all,
This soundcard is an old (~1998) Ensonic AudioPCI E1370. It is powered from the +12V (10A) and -12V lines (1A) of the PC PSU. Looking at the datasheet for the LM1876, here, the LM1876 can only give ~8W at +/-12V. So what can be done to increase power output from the LM1876: 1) Can the +5V and +12V, and -5V and -12V be joined to to give +/-17V? will the low current of the -5v be a problem? 2) Change rectifiers of -12V line to give higher current to match the +12V line? Will this make any difference, since the LM1876 will still draw essentially the same current at -/+12V? 3) Can you combine +5V and -12v, and -5V and +12V to give +/-17V? 4) Can anything else be done to increase the voltage from the PSU above +/- 12v? (mess with pin 1 of the tl494 pwm regualtor IC. etc?) ta |
| xlr to pc-soundcard | MrAmp | Analog Line Level | 0 | 10th August 2011 08:08 PM |
| Best PC Laptops for running test tools -Clio , PC Scopes etc. ? | Hearinspace | Multi-Way | 12 | 12th August 2008 11:54 AM |
| Active XO using PC soundcard? | mr_push_pull | Multi-Way | 9 | 1st December 2005 06:31 PM |
| Page generated in 0.06679 seconds (65.32% PHP - 34.68% MySQL) with 10 queries |
