Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th October 2011, 05:58 PM   #1
Default toroid question
Howdy!
I have toroid transfo with dual secondaries (120V and 6.3V).
I tried hooking up the 6.3's (blue from one sec. with the green from the other) to make 12.6 V, but I didn't get any values? And the transfo got quite hot?
Before hooking them up together, I did first measure I was getting 6.3 from them.
Where did I go wrong?
Do I also have to connect the two input leads (black and red) together as well? I'm thinking would that give me 230V?
cheers,
Norm
Old 17th October 2011, 05:59 PM   #2
Oh, I forgot to provide the link to the transfo:
Antek - AS-05T120
Old 17th October 2011, 06:10 PM   #3
DF96 is online now DF96  England
The datasheet is quite clear. You need to identify which winding is which. I assume you understand about the difference between series and parallel wiring?
Did you connect the blue and green together on the same secondary, instead of different ones? A lamp limiter would provide protection in case you get it wrong.
Old 17th October 2011, 06:14 PM   #4
When color codes are correct:
primary (input) blacks together and reds together is for 120 V line (two primaries parallelled);
secondary blue from one with green from the other should give 12,6 V (unloaded voltage will a bit higher though); maybe a wrong color code there.
Old 18th October 2011, 12:54 PM   #5
There is always a chance, however remote, that the cables are wrongly coded.
Always use a bulb tester until you have convinced yourself that the wiring is correct.
regards Andrew T.
Please Help Toroid Question for F1 milezone Power Supplies 6 27th August 2009 09:40 PM
toroid question slr 5000 Power Supplies 21 19th June 2008 09:58 PM
Toroid question amisdad Chip Amps 6 25th September 2004 07:59 AM
Page generated in 0.18959 seconds (36.53% PHP - 63.47% MySQL) with 10 queries
