Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th October 2011, 02:37 AM   #1
Default Tube rectification for DAC SS analogue
hi guys
i am considering using 6X4 to power an analog SS dac out that has max 20mA current draw. toying with duncan psud, i need 40vac to get rectification of around 20vdc.
what are the tubes recommendation? would 6X4 be sufficient?
i am wondering if anyone has tried powering the dac output SS stage with tube rectification? whats the configuration?
thanks in advance
erwin
Old 19th October 2011, 06:17 PM   #2
Anyone?
Old 20th October 2011, 12:49 PM   #3
DF96 is online now DF96  England
Maybe nobody has tried it. Why do you think that might be?
Old 20th October 2011, 01:37 PM   #4
kevinkr's Avatar
Originally Posted by milen007 View Post
hi guys
thanks in advance
erwin
I've seen a couple around on the web, but unfortunately no recollection where.. I would think something like a hexfred would be a better choice, and should provide the soft turn off characteristic you get with tube rectifiers without the losses and high source impedance.
I would suspect that the dac is not operating on 20V and that there are a bunch of small linear regulators making the local voltages required - this would negate any sonic 'benefit' of the tube rectifier..
www.kta-hifi.net
Old 20th October 2011, 05:19 PM   #5
Thanks Kevin for the inputs
It would be lovely if ya can recall the keyword for Google search. But in the mean time I would just go with Salas reg before any working solution is found using tube rectifier
Erwin
SS Rectification coldcathode Tubes / Valves 4 5th October 2009 03:41 PM
Tube rectification for SS cicuit dsavitsk Power Supplies 6 16th July 2005 11:04 AM
SS vs. Tube Rectification (and chokes)? Sherman Tubes / Valves 48 6th December 2004 10:48 PM
Dac or Cd player SS or tube that is the question jswillis73 Digital Source 0 25th March 2004 04:47 AM
Page generated in 0.07583 seconds (77.37% PHP - 22.63% MySQL) with 10 queries
