Hello,
I would like to build a LM1875 amp. Actually, I already built one from a design in MAKE magazine, but it was a failure because it was much quieter than I thought it would be, plus it overheats. The design called for a RadioShack transformer, 12.6V per rail and only 0.5A. I really don't know what I'm doing, but I realize now that transformer sucks. I think I need more power. But I don't want to spend more than $50 on it. Is there anything you can recommend that would be more suitable?Thanks! Mossen |
#2 |
Checking the data sheet for the LM1875 shows a "recommended" supply of around -/+25 volts... this comes back to your earlier question
... and so an 18-0-18 Vac transformer such as this,MULTICOMP|MCTA100/18|100VA TOROIDAL 2X18V | CPC would allow for a a compact stereo power amplifier (two LM1875's) to be constructed. The 18Vac would give approx 25 volts after rectification and smoothing (18 * root 2 to calculate) So that gives a -/+25 volt supply.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Thanks Mooly. One more thing: As I am considering transformers, what other things should I be looking for, aside from whether it meets the power requirements? Is there any other specs that will tell me the quality or performance of it? Any brands you tend to go for over others? Any to avoid?
Thanks! Mossen |
#4 |
A link to your schematic would be helpful.
Here it is, I think: makezine.com: Squelette, the Bare-Bones Amplifier And here is a discussion thread with the author/designer: LM1875 integrated Chip Amp with external PSU - Page 3 - AudioKarma.org Home Audio Stereo Discussion Forums Dowload the datasheet: http://www.national.com/ds/LM/LM1875.pdf Here is the power supply schematic: http://makezine.com/images/23/MAKE23...pPwrSupply.pdf It looks like you used the wrong transformer. They show a 25.2VCT (center-tapped), 2 Amp transformer. For that, you could use a Hammond 185e24 or equivalent, which is shown at Mouser Electronics - Electronic Component Distributor 546-185 for $27.75 for qty 1. That one is rated at 3.3 Amps max, instead of 2A. Or you could use the 546-266L24 2-Amp model for $29.66. And there are others that would work. Since you don't need the dual secondaries, you could tie them together in the middle, to have a center-tapped transformer. Here is another guy who built one: LM1875 Chipamp I would probably use a different schematic, and use a power supply that could produce +25v/-25v or so, as Mooly suggested, so you could get 25 Watts per channel instead of 10 Watts per channel, into 8 Ohms. Last edited by gootee; 16th October 2011 at 08:19 PM. |
#5 |
Yes, that's the one I was trying to build. I had it working, but it had problems as I mentioned above. Plus I hard-wired the whole thing and for this next iteration I'm going to etch a board (something else I haven't tried doing yet
). So I'm trying to make it again, except more robustly. Also, if you look at the power supply schematic, you'll notice there's a 500mA fuse to the transformer. This is why I said the amp operated on 0.5A. Is this correct assumption? Why would the designer limit a 2A transformer to 0.5A? Also, (assuming the fuse wasn't there) what would prevent the circuit from drawing more current than 0.5A? The internal circuitry of the amplifier itself? Schematic is here: http://makezine.com/images/23/MAKE23...pSchematic.pdfMossen |
#6 | |
Look at the "regulation" figure of the transformer. The rated voltage is always quoted under the transformers rated load. Off load (nothing drawing current) and the voltage rises by the "regulation" figure. So the 18 volts could be up 8% higher for the one I linked too. That means the -/+ 25 volts is nearer -/+ 28 volts. Usually the larger the transformer (a bigger VA rating) and the better (lower % figure) the regulation.
#7 |
Following on from Mooly.
If you find two transformers of the same type and same Vac and same VA but with different regulation, then generally the higher regulation transformer has used fewer materials and/or cheaper materials and this should reflect in the price. If the price were the same I would be very tempted to go for the lower regulation. But there is hidden quality, that needs to be paid for. A quiet transformer looks just like a noisy transformer. I can't tell them apart in a specification sheet.
regards Andrew T. |
| power transformer recommendation | nukaidee | Tubes / Valves | 31 | 13th December 2008 03:34 AM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| transformer selection recommendation for aleph 30 | hc167 | Pass Labs | 12 | 27th March 2007 04:33 AM |
| Aikido Transformer recommendation | Original Burnedfingers | Tubes / Valves | 0 | 14th March 2007 10:51 AM |
| Aleph 30 transformer recommendation | SteveA | Pass Labs | 23 | 26th April 2006 03:25 PM |
| Page generated in 0.10593 seconds (79.36% PHP - 20.64% MySQL) with 10 queries |
