Hi. I'm planning to build a simple LM1875 amp. It will be my first one. If I use a power supply that can provide 15V at 2A, is this the ultimately same as one that can provide 30V at 1A?
Thanks mossen |
#2 |
They're both 30VA, so if by "same" you mean power output the answer is yes.
But you probably want a little more power to run your LM1875.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#3 |
If it is a single PSU of just 15 volts (single as in not a split rail of -/+15) then that means the LM1875 can only swing a theoretical -/+ 7.5 volts across a load.
For an 8 ohm load that equates to only around 5.3 volts RMS giving a power of 3.5 watts RMS. Factor in losses in the IC and your nearer 3 watts or less. For the 30 volts supply the power goes up to nearer 14 watts RMS. So although your 15 volt 2 amp supply may seem equivalent to a 30v 1 amp supply the problem is that you can't put that "power" down across the load.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
Thanks Mooly, for that explanation. Makes sense!
| power supply design question 832A amp | trondareo | Tubes / Valves | 3 | 9th June 2010 10:08 AM |
| Amp power supply question | theAnonymous1 | Solid State | 12 | 30th August 2008 05:06 AM |
| Car amp internal power supply question | Thunau | Power Supplies | 0 | 24th September 2006 02:57 AM |
| power supply question for SI T-AMP | michelevit | Chip Amps | 9 | 7th November 2005 11:07 AM |
| T-Amp power supply question | The Rocker | Class D | 2 | 27th May 2005 08:47 PM |
| Page generated in 0.07534 seconds (70.08% PHP - 29.92% MySQL) with 10 queries |
