http://www.meanwell.com/search/scn-800/scn-800-spec.pdf
does anyone have any experience with these? I have four of the 20volt version (not listed in the PDF) which I want to use to charge a 16volt battery bank. plan is to connect them all in parallel, set to ~19volts to charge the 16volt bank. now, using the SMPS internal regulation, and the internal "V-Adj" control, with the "Par" connection made between the 4 powersupplies, will I have to adjust them all? or just one control? what does the "par" (parallel) connection even do? how is it any different to just connecting the output from the PSUs in parallel? thanks! |
#2 |
The PDF is not clear on the operation of the "V-Adj" in parallel mode, but the 'par' connection would be involved in the regulation of the output, which keeps variations in the output voltages from burning up each other, or burning up the wires feeding the load if there is a significant difference in resistance.
I would personally use the remote sensing configuration to eliminate that as a possibility, but the 'par' cinfugration should be sufficient. Just curious, what type of batteries are you planning to charge that need or withstand 120A of charging current? |
#3 |
#4 |
that green carpet looks familiar from somewhere
| Dual-jFET 2SK146 and two single jFETs 2SK147 in parallel Operation in Luxman's L550 | tiefbassuebertr | Solid State | 2 | 28th September 2011 09:44 AM |
| Meanwell SMPS and LM3886? | THUMP LUMP | Chip Amps | 63 | 25th November 2010 10:38 PM |
| meanwell ??? | jrcanoe | Power Supplies | 1 | 6th April 2010 07:12 PM |
| Parallel operation of triodes. | ashok | Tubes / Valves | 9 | 14th June 2008 08:43 PM |
| can I run 2 torroid in parallel operation? | ericpeters | Solid State | 10 | 24th November 2004 05:08 AM |
| Page generated in 0.07852 seconds (70.15% PHP - 29.85% MySQL) with 10 queries |
