I have a transformer which doesn't have absolutely any labels or markings.
The only thing I know is that the primary voltage is 250Volts. How do I figure out which one is primary and which one is secondary? (using multimeter or anything else) |
#3 | |
What is the theory behind this? It's a step down transformer and non center tapped. Last edited by kokuhorice; 14th October 2011 at 03:28 PM. |
#4 |
A step down transformer has fewer turns on the secondary than on the primary.
Fewer turns = lower DC resistance.
Frank |
#5 |
Thanks a lot Pano & Frank Berry.
I was able to figure out the primary & secondary of the transformer. The primary had 2.5 KOhms and the secondary had 80 Ohms. It turned out to be a 9V transformer which I used in one my projects. |
#6 |
^that's a mighty small traffo....
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#7 |
Yes, probably <6VA and maybe as low as 1 or 2VA.
Could the 80r secondary indicate that the transformer has been designed to survive a short circuit on the output?
regards Andrew T. Last edited by AndrewT; 18th October 2011 at 12:52 PM. |
#8 |
Sorry, the secondary had 18.4 Ohms.
| is transformer with primary and secondary = isolation? | milen007 | Power Supplies | 5 | 1st February 2011 11:30 AM |
| Using primary as the secondary winding in the power transformer. | mishak | Parts | 10 | 30th May 2010 05:55 AM |
| safest way to identify primary/secondary? | gary h | Power Supplies | 15 | 6th January 2010 03:56 PM |
| Why a Zobel network across OPT primary or secondary? | ray_moth | Tubes / Valves | 6 | 4th March 2005 10:26 PM |
| Using the secondary of a normal transformer as the primary to get a HT supply | baggystevo82 | Parts | 9 | 2nd April 2004 11:02 PM |
| Page generated in 0.07529 seconds (83.26% PHP - 16.74% MySQL) with 10 queries |
