Hi All,
I have just spent several weeks trying to fix a Fender Rhodes power amp which was blowing fuses, i was convinced the transformer was short circuit as the coil resistances were less than 2 ohms. I finally realised there was a short circuit on the rectification and smoothing board, but there was no sign of any shorts using a meter. Changing all the electrolytics sorted it out but none appear short circuit with a meter. My question is how can these type of faults be tested? Thanks Tim |
#2 |
To seriously test an electrolytic you should measure the value on a bridge and note the dissipation factor. If the DF is high, the cap is on its way out, regardless of what the value measures. Cp is also better clue than Cs. You should also do a high voltage leakage test at the voltage rating of the cap. If the leakage is above the datasheet value the cap should be tossed. My guess is the cap(s) were breaking down at voltages above what your meter applies to measure resistance.
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 |
If possible its always worthwhile powering up with just bridge and smoothing capacitors connected to see if fuse blows.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| non-polarised electrolytics | hitsware | Parts | 5 | 11th September 2010 08:46 AM |
| series electrolytics.... | jmillerdoc | Power Supplies | 3 | 10th August 2010 10:28 AM |
| Replace Electrolytics? | Monjul | Tubes / Valves | 9 | 5th February 2010 06:03 AM |
| Bipolar electrolytics | dsavitsk | Parts | 3 | 8th January 2006 10:48 PM |
| Electrolytics 101 | Frazzled | Parts | 3 | 21st May 2004 01:49 AM |
| Page generated in 0.06971 seconds (74.16% PHP - 25.84% MySQL) with 10 queries |
