i'm an average joe and i'm trying to repair my 1st amp.i found 2 of the power supply mosfets blown,they smoked as soon as i hooked up the ground and +12v leads to the amp,the remote turn on lead was not even hooked up.i bought the amp broke,so i do not know the history of the amp.any ideas what else should i replace,and what could've caused this?
#2 |
well, start with basic, take DVM and measure short between 12v and ground. By now you already know you have one... then remove power supply fets (I think once one goes, they all go, that's why you would need to remove all of them). Once you do that, check for short again. if still there, you need to find the components that is making it (not by applying power to amp).
And if all this is to cmplicated already, your best bet is get send amp to get it fixed, and probably not to friend of a friend that knows,.... unless he knows what he is doing Amp goes up in smoke, well it can go for many reasons, one of them is vibration (people put amps on boxes, which flex with amp, and that breakes things inside of amp) |
#3 |
when i got the amp,i found 6 ohms between the +b and ground leads.i had no idea that all the fets were bad if only one smoked so i applied 12v with a 10amp fuse inline,thats when i noticed 1 fet(Q6) smoking.i imediately removed the voltage and cut the pins on the smoking component,checked the resistance again at +b and ground again and found 20 ohms ,so i cut the pins on the fet(Q7) next to the smokin one and then the resistance disappeared.
#4 |
really? now I don't really know which two fets are those, what they do in circuit, but hell, if you are trying it like that, did you power it now?
apart from taking scope and/or dvm you won't be able to know if it works and what does not. Unless it will power up and play music, but that should be first time ever |
| rockford fosgate t2000-1bd blown power supply mosfets | 2sheezy | Car Audio | 15 | 4th October 2011 12:50 AM |
| Rockford Fosgate 160.2 MOSFETs? | lukeman269 | Car Audio | 4 | 2nd September 2011 08:44 PM |
| Rockford Fosgate 60ix FETs blown | LazySteve | Car Audio | 12 | 23rd June 2011 08:48 AM |
| Blown Rockford Fosgate 250M, help a newb =-) | mkfosgate | Car Audio | 11 | 26th July 2009 07:23 PM |
| Rockford Fosgate 501s power supply | RJCRAFTS | Car Audio | 3 | 15th January 2009 02:57 AM |
