I need some ideas for generatig +/- 20 VDC from a +/-60 VDC power supply.
The maximum current requirement is approx 200mA. I could go for a linear regulator, but it will cause approx 16watt dissipation in the regulator. Does anyone know a simple switcher, that can do this. I have no problem finding the positive version, but the negative seems hard to find.... |
#2 |
If the Transformer has Dual secondaries as opposed to a Center tapped secondary then you can use the Positive voltage regulator for the Negitive rail , you would just use the positive as ground and ground as negitive ......
That is a lot of heat to disapate with a single regulator but you can use a pass transistor to help dissapate that heat , the regulators datasheet should show how to do this ...... You might also consider just using only half of the power transformer and do a Voltage doubler which will give you +/-30v DC that will be a lot easier to regulate down to +/-20v DC , you would need to use about double the capacitance in the PSU than before because on the increased ripple voltage from the voltage doubler ....... Cheers |
| FS:6600 uF 60 VDC caps | Dick West | Swap Meet | 5 | 27th December 2011 04:44 AM |
| WTB: 120VCT (60-0-60) transformer for balanced power supply | jmillerdoc | Swap Meet | 2 | 14th April 2011 06:08 PM |
| Yamaha M-60 power amp for sale (w/ impaired C-60 preamp) | rainzoneman | Swap Meet | 10 | 3rd December 2009 01:44 PM |
| 12 vdc to 18 vdc isolated P-P | jamesrnz | Power Supplies | 89 | 4th February 2009 03:36 PM |
| Peavey Classic 60/60 bias mod advice | RIC | Tubes / Valves | 5 | 23rd March 2005 06:16 AM |
| Page generated in 0.06475 seconds (74.18% PHP - 25.82% MySQL) with 10 queries |
