Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd October 2011, 05:33 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default PWM input voltage compensation
I'm currently using the PWM circuit shown below. I will have a varying input from 24V to 0V and I need some positive feedback to compensate for the voltage dropping to 12V. How can i do this? Replace the pot with 2 transistors and bias them appropriately? If i use BJTs (I was thinking BC547 and equivalent) will I need the two diodes?
Boscoe
I thought about it once, but then thought again.
Old 4th October 2011, 05:23 AM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
what drops to 12v? why don't you just make this circuit, and before pin8 and 4, make 12v regulator, so that you'll input 24v to it (and drive motor with such voltage too), while supply only 12v to 555 which drives fet
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 4th October 2011, 06:57 AM   #3
Sorry I should of been more specific. the design goal of this is to save energy so lnear regualtors are out of the question. The 555 is going the be driven by batteries but the motor is going to be driven by a bank of capacitors so compensation for their voltage degeneration is needed, I have designed another circuit to switch the capacitors over to battery power once they reach a critical voltage.
Old 4th October 2011, 07:56 AM   #4
I think your requirement can be easily achieved using sg3524. Check it datasheet. If you need further guidance Ping me back.
There is always a first time....
Old 6th October 2011, 04:39 AM   #5
dropping the voltage delivered to the 555 to 12v with a linear regulator will reduce the joules dumped into the fet and save you some power because the energy needed to switch the fet rises with voltage squared.
PWM output voltage is just only 0.14Vrms! nonprof Car Audio 7 12th July 2011 01:29 AM
Ripple reduction with added voltage compensation to HV trobbins Tubes / Valves 11 25th April 2011 11:04 PM
PWM amplification with I2S input? Mitch311 Class D 3 31st March 2011 10:34 AM
X Aleph absolute voltage compensation scheme macka Pass Labs 8 13th September 2008 03:30 PM
HELP: BJT input op-amp's input bias current compensation frickecello Solid State 6 19th June 2007 12:00 AM
Page generated in 0.10519 seconds (67.05% PHP - 32.95% MySQL) with 10 queries
