Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd October 2011, 07:00 PM   #1
Send a message via Skype™ to Alexrmc92
Default 6992 Pre Amp PSU, whats wrong here?
Heres a pic of a single tube 6992 tube pre-amp power supply that im working on. The top supply is for B+ and the bottom is for the heater.
Now in multisim i can only measure 50v no load on the B+ supply. If i remove the grounds and wire the top circuit together with wire instead of the grounds i get 100v. So is the bottom circuit somehow drawing current from the top circuit? Or is this just a multisim error? 100v no load is what im looking for on the top circuit.
Old 2nd October 2011, 10:20 PM   #2
I ended up fixing my problem. Anyways here's the new circuit. R5 simulates the tube heater and R4 simulates the plate resistance.
Should i regulate the plate voltage? Similarly to how i regulated the heater voltage?
Anything obviously wrong with my mic pre amp ? nigelwright7557 Tubes / Valves 16 7th July 2008 09:43 PM
New stock pre -amp tubes. Whats good? RockysDad Tubes / Valves 7 3rd March 2006 09:46 PM
Amp Turns on and off whats wrong?? db junkie Class D 2 26th October 2005 12:09 PM
Whats Wrong with My Chips! Marvellous Chip Amps 5 29th April 2004 12:16 PM
Page generated in 0.06710 seconds (69.49% PHP - 30.51% MySQL) with 11 queries
