Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th September 2011, 10:12 AM   #1
pvh1987 is offline pvh1987  Denmark
Default Torodial transformer - help with secondary windings
I need some help with secondary windings on a torodial transformer.
I have a 80VA torodial transformer with 2300 primary windings (it is made for 230V-50Hz on the primary). I want to make several secondaries, 2x33V, 2x18V and 1x8V - that is 5 secondaries
1. I suppose that for winding 2x33V, I can wind both 33V windings at once, by winding two wires at once counting 330 windings from 0 to 360 degrees. If the wire diameter is too thick compared to the inner diameter of the torodial to allow that, I can wind the windings so that some of the windings overlap?
2. Does the windings have to go from 0 degrees to 360 degrees? Can I wind two times around the torodial - from 0 degrees to 720 degrees, counting 330 windings total and still get 33V output?
Old 29th September 2011, 09:21 PM   #2
1. Yes, the windings can overlap. In theory this will not effect the transformer; in practice it won't make much difference at 50 or 60 Hz.
2. This question seems redundant, but you can put multiple layers of turns.
Old 2nd October 2011, 06:45 PM   #3
seebert is offline seebert  United States
I wound a lot of toroids for PSU's back in the 70's and found that it didn't make the slightest discernable audio difference when overlapping windings ... and windings upon windings; there's just so much space and so long as the windings are 'tight and close' (i.e. not like a typical RF excluding ferrite ring) most everything else didn't effect performance.
Shorted secondary windings of transformer Edvard Tubes / Valves 5 29th December 2010 10:22 PM
adding and using secondary windings jrenkin Power Supplies 0 19th April 2010 03:05 AM
torodial transformer question sakis Solid State 6 18th December 2009 07:44 AM
cap btween primary and secondary windings? sam9 Power Supplies 8 19th May 2005 06:34 PM
Parallel secondary windings jlm Pass Labs 6 27th March 2004 10:39 AM
Page generated in 0.08246 seconds (71.78% PHP - 28.22% MySQL) with 10 queries
