Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th September 2011, 11:52 PM   #1
Minion is offline Minion  Canada
Default Simple PSU question .....
Hi guys , I have a quick question .....
I have a 12v DC supply that can put out 500ma and I want to regulate down to 6.3v using a lm317 regulator and need to know if I can still get 500ma from the supply ??
Thanx guys .....
Old 28th September 2011, 12:07 AM   #2
nigelwright7557's Avatar
Yes.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 28th September 2011, 12:19 AM   #3
Thanx Nigel ......
Old 28th September 2011, 12:26 AM   #4
...but the thermal resistance junction-ambient of the TO-220 case, which is probably the one you've got, is 50 degrees C/watt, and dropping nearly 6V @ 0.5A is nearly 3 watts, which'll make it temperature limit before it gets to 150 degrees above ambient, but be careful, because it'll give you a nasty burn. You'll need a heatsink.
Old 28th September 2011, 01:57 AM   #5
Thanx ... I got lots of chunks of aluminum laying around that I can bolt the LM317 up to .....
I"m using it for a DC heater supply for a 6v6 tube amp so it will suck 450ma , I actually found a 9v DC 1A walmart that I stole the transformer from for this PSU so it should dissapate a bit less heat the 12v one ......
Thanx again .....
Old 28th September 2011, 10:41 AM   #6
DF96 is offline DF96  England
Why use DC heater for a 6V6? Are you using it as the first stage in a phono preamp??
Old 28th September 2011, 04:02 PM   #7
! is offline !  United States
The 9V, 1A supply is better for a second reason too, it would be operating at half capacity instead of near 100% as the 12V 500mA would.
Say 9VDC wart transformer rises in voltage a little while half loaded to 9.4V (random guess, fudging till you have a measurement), (9.4V - 6.3V) * 0.450A = 1.4W, it'd get hot enough that it would still be nice to have a small heatsink on it.
Old 28th September 2011, 11:18 PM   #8
I"m using DC heaters because it is impossible to find a 6.3v transformer where I live and I have a box full of AC and DC adapters to scavange Transformers from......
I could just use a resistor to drop the AC down to 6.3v I suppose but figured I got lots of Diodes , capacitors and lm317 regulators so why not make a nice regulated DC supply ......
I"m going to be useing about 14,000uF of capacitance in the supply so it should be fairly clean DC from the supply .....
Thanx
Old 28th September 2011, 11:35 PM   #9
you could just unwind some of the secondary from the 9V you have...
Old 28th September 2011, 11:52 PM   #10
I wouldn"t trust myself to do that and not screw it up ......
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
simple PSU Question.. deepanger Solid State 15 28th August 2003 10:49 PM
Simple PSU question Magnetmaz Tubes / Valves 4 24th April 2003 03:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
