Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th September 2011, 09:47 AM   #1
Default Dumb question time - tapped choke
I have a pair of large, three terminal chokes. Now I'm going to use them for a choke input supply to generate B+ for a PP2A3 amp.
I'm trying to recall how the tap on the chokes might be used. I've read it somewhere but can't find it in my notes anywhere.
For the parts mavens, they are marked R.T. 103 with terminal 1, 2 and M About 1kg in weight, steel case but not hermtically sealed
Thog
Old 25th September 2011, 02:59 PM   #2
are all 3 taps on the same winding?
measure the resistance between the 3 terminals. Which pair gives the highest resistance?
Does the other terminal to each of it's partners give resistances that add up to that highest resistance?
regards Andrew T.
Old 2nd October 2011, 07:02 AM   #3
Apparently not - 64 ohms between two, >1M to the third. So it appears to be a conventional choke.
There's a little "E" printed next to the third so I presume it's for earth.
Although it is not connected to the can or mounting lugs.
center tapped choke inverter alexg Tubes / Valves 48 8th July 2007 11:45 PM
A quick, dumb question on time-alignment Cloth Ears Multi-Way 4 25th September 2006 07:17 AM
Help with a choke for first-time DIY... mr mojo Tubes / Valves 9 5th August 2005 10:03 PM
Center tapped choke loading Bandersnatch Tubes / Valves 10 8th July 2003 11:56 AM
Page generated in 0.07573 seconds (68.99% PHP - 31.01% MySQL) with 10 queries
