Somebody help me understand the principles behind this DC blocker? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd September 2011, 03:53 AM   #11
Originally Posted by benb View Post
Yes, maybe - the AC voltage across the caps will be pretty small, as a SWAG maybe only 0.1V. Knowing the capacitance, one could calculate reactance at line frequency, and from that and the current pulled by the transformer calculate the voltage across the caps.
So that's what he's doing... the larger the capacitance, the lower the voltage drop?
But the caps will still see reversed voltage, right? I wonder how long they will last like that, even with low V.
Old 26th September 2011, 02:10 AM   #12
expert in tautology
bear's Avatar
use AC rated caps, avoid the problem?
it will just be larger and cost more...
_-_-
PS i think that current rather than voltage will be the bigger issue for electolytics...
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 26th September 2011, 02:56 AM   #13
benb is offline benb  United States
Yes, they'll see reverse voltage. As he says or implies, electrolytics are apparently not "really" damaged as long as the reverse voltage stays below a volt or so. Worst case is they short out, and the transformer is connected directly to the line, which it would have been anyway without this circuit.
Apparently the biggest source of reverse voltage would be any DC offset on the line.
Old 26th September 2011, 03:24 AM   #14
nm
So is this worth doing for a linear supply?
Old 26th September 2011, 04:35 AM   #15
That calls for an opinion, and that's above my pay grade.
Old 26th September 2011, 02:16 PM   #16
expert in tautology
bear's Avatar
If ur transformers are humming, give it a shot...
_-_-bear
otherwise, ya know what else works?
an isolation transformer - it doesn't pass DC offset... fwiw.
_-_-bear
DC blocker diode/cap orientation Glen B Solid State 8 28th December 2014 05:16 PM
Help me understand DC servo FB. Artie Solid State 5 23rd June 2009 09:13 PM
I just installed Yeos (DIY Paradise) DC Blocker duderduderini Tubes / Valves 10 2nd October 2007 11:57 PM
dc blocker test report jeapel Pass Labs 5 4th July 2007 04:46 PM
Copyright 1999-2017 diyAudio
