Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th September 2011, 07:02 AM   #1
formula 22's Avatar
Red face SMPS a converter - help!
Hi
I'm working on this SMPS project under the schematic Figure 1.
The only problem that I can not resolve is the ferrite transformer. It has a toroidal ferrite as the datascheet-in (tn322913).
Now I ask you for help, how to get to the exit 2x35V/2x5A. How winding wires should have a primary, secondary and how much and what section, at the same operating frequency to be 40kHz.
Old 18th September 2011, 08:32 PM   #2
darkfenriz's Avatar
dB= V*T/ 2*N1*Ae
V=2*12V (for push pull)
T=25us=25E-6s
N1 (primary turns)=?
Ae=76.5 mm^2= 76.5E-6 m^2 (from datasheet)
dB should be chosen for acceptable core losses, for 40kHz I would recommend around 150mT for safe and relatively cool core operation. Consult core losses table in datasheet.
So, calculate N1 first:
N1=V*T/2*Ae*dB=
= 24*25E-6/2*76.5E-6*0.15 = 26 turns (each primary)
Turns ratio is the same as the voltages ratio between primary and secondary, so N2=26 turns * 35V/24V = 38 turns
Old 19th September 2011, 02:47 AM   #3
formula 22's Avatar
Originally Posted by darkfenriz View Post
dB= V*T/ 2*N1*Ae
T=25us=25E-6s
N1=V*T/2*Ae*dB=
Thank you, Mr.darkfenriz!
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 26 5th July 2011 10:22 AM
V/I Converter blu_line Solid State 24 26th December 2006 09:57 AM
SMPS - Buck converter - HOW !? -_nando-_ Power Supplies 20 19th December 2005 02:14 AM
Boost converter vs. SMPS GhettoSQ Car Audio 9 22nd July 2005 09:40 PM
car chipampzee without smps/ dc-dc converter? kita Car Audio 4 1st March 2005 01:17 AM
Page generated in 0.08249 seconds (77.97% PHP - 22.03% MySQL) with 11 queries
