Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th September 2011, 07:11 PM   #1
Smile Power Supply Bypass Cap?
Looking for some help on adding a bypass cap to my Marantz 2220B Power Supply Board I am working on. What jumpers should it go across and what value cap should I use. Please see Pic of board etc. below: Click on image to enlarge.
Old 17th September 2011, 08:05 PM   #2
agdr is offline agdr  United States
agdr's Avatar
A little more info, please, on what you are trying to achieve here. Does it have a problem right now or are you looking to just buff something up?
If you are asking about a high frequency bypass capacitor across filter electrolytic(s) then that is typically a 0.1uF ceramic across C803, C804, or both. If there is room/clearance on the bottom of the PC board you could solder the 0.1uF's directly across the electrolytic pins there. C803, R801, and C804 are forming a CRC filter going into the regulator.
Something like these:
http://search.digikey.com/scripts/Dk...=478-3146-1-ND (Digikey)
KEMET|C330C104K1R5TA|CAPACITOR CERAMIC 0.1UF 100V X7R | Farnell United Kingdom (Farnell)
This type of bypass solves the problem of the electrolytic having a large(r) series inductance which increases impedance at higher frequencies. The ceramic has a low inductance. There is no polarity on ceramics, of course (no + lead). You can solder it in either way across the electrolytic pins.
Old 17th September 2011, 08:18 PM   #3
If you are asking about a high frequency bypass across filter electrolytic(s) then that is typically 0.1uF ceramic across C803, C804, or both. If there is room/clearance on the bottom of the PC board you could solder the 0.1uf's directly across the electrolytic pins there. C803, R801, and C804 are forming a CRC filter.
Something like this:
Hi, thanks for the taking the time to look at this for me. There are no problems, I am restoring this unit and am now working on the power supply board and was just looking for any tweeks I could perform to help the sonics of this unit even if it is something small. I will use your suggestion on C804.
Old 17th September 2011, 08:30 PM   #4
agdr's Avatar
Sounds good! I just added a Farnell number too. Just a standard disk ceramic 0.1uF rated 100V or above would work just fine also.
Old 17th September 2011, 09:14 PM   #5
DF96 is online now DF96  England
The best place for a bypass, if you feel one is necessary, is the amp board not the PSU board.
Old 17th September 2011, 09:50 PM   #6
Ron AKA is offline Ron AKA  Canada
I think I would go with a 0.47 uF metalized polypropylene cap. You have a voltage regulator so it may help more after the regulator than before, or do both. You could also upgrade the two main caps by increasing them 50% in size and looking for a low impedance design. The Panasonic FM or FR would do for a 680 uF and 50 volts. A Chemicon KZE would do in the 63 V location.
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Polar electro with bypass cap to replace nonpolar as coupling cap? at77 Parts 0 12th January 2010 02:05 AM
Bypass caps on power supply digital desire Solid State 55 18th January 2007 04:15 PM
Want to bypass power supply, but... beanbag Chip Amps 1 17th November 2005 04:47 PM
Power Supply Bypass Caps dsrviola Solid State 1 3rd November 2002 07:15 PM
Page generated in 0.10092 seconds (76.65% PHP - 23.35% MySQL) with 10 queries
