Is it always necessary to use coupled output inductors with an offline current mode full-bridge smps supplying split class d rails.?
Power = 330W. the Vout = +/-50V. I hear that the method of increasing cross-regulation by using coupled output inductors is always needed when using current mode control. Page 3, part 5 of this App Note states that current mode means coupled output inductors are needed....... http://www.ti.com/lit/an/slua119/slua119.pdf is this right? |
#2 |
Strictly speaking, NO, coupled inductors are not required for current mode control. But for a +/-50V output, it would be advantageous to use a coupled inductor whether the power supply was current mode or voltage mode controlled. By adding slope compensation as Mammano suggests in note 2 of that same section, you add a fixed ramp to the current signal, which makes it more like a voltage mode controller.
Is there some objection to using a coupled inductor? They get messy when you have differing low voltage outputs because you have to control the leakage inductances to prevent circulating currents between the outputs, but with +/-50V it seems like a really good idea. |
#3 |
The problem with using a coupled inductor is that when one half of the split output is fully loaded, the other half sees the coupled inductor as a very high inductance, and so its transient response, should its output suddenly become loaded, is very solw, and slow transient response is not good, as you know, for audio purpose.
#4 |
You're right, an SMPS perfect for audio amplifiers, you can not develop with the chip manufacturers. pfc, phase shift and sync rectifiers, have nothing to do with the transients of an amplifier. I estimated at about 150ns response time to fully adapt to the demands of current.
Therefore, you can only increase the filtering capacity. or build something new specifically for amplifiers. (with your chips and your topology) Regards |
#5 |
If this is a forward converter with a +50V and a -50V output and a single control loop, then a coupled inductor will give you better load transient response on the unregulated output than having two separate inductors. The "coupled inductor" is also a transformer that keeps the voltages across the two windings the same during the ON and OFF switching periods. When the unregulated output has a load change, the currents are reflected to the regulated output through the transformer action of the "coupled inductor." This improves both DC regulation as well as transient response.
I have been assuming this converter is a single-ended forward converter like the ones shown in Bob's apnote, is that correct? |
#6 |
the converter here is a full-bridge SMPS, supplying isolated split rails of +/-50V. Would i be right to suggest that if i am using uncoupled inductors of 47uH......then if i want to switch to coupled inductors......i make them 47/4 uH? ....ie the inductance of one winding, with the other open, would be 47/4uH? ..Also, is there something about making the inductance of the coupled windings the same as the transformer secondary?.....i.e., it wont work if theyre not the same? Last edited by eem2am; 18th September 2011 at 03:55 PM. |
#7 |
Calculate the inductance as if they weren't coupled (so if 47 uH is the right number, the two windings on the core will each measure 47 uH).
Then size your output inductor core to handle the total expected DC (and AC Peak) output current. If the outputs are the same voltage and you are using the same kinds of rectifiers on both outputs then the winding ratio is 1:1. No, you do not need to match the inductance of the output choke to the transformer inductance. Some of the old unitrode apnotes are still around on the TI website that tell you to match the inductor ratios to the transformer ratios, but that approach is simplistic and can cause a lot of trouble. Also, a word of caution about the Unitrode suggestions about slope compensation (the full bridge will operate at nearly full duty cycle, so you are over the 50% duty cycle that Mammano mentioned in the apnote article 2), so do your homework! the Unitrode apnotes were written before Ridley & Fred Lee published their work on current mode control, and some of the old cookbook stuff is not entirely the right way to go. Good luck on this one! |
#8 |
OK thanks......i am using voltage mode......so i will not need slope comp..but thanks anyway.
My input DC Bus is 190V to 373V, so you are right, much slope compensation would have been needed. You may agree with me that when a lot of slope compensation is needed, it is a bad idea, and one should simply change to voltage mode control. ...this is because when you have a lot of slope added, one has to reduce the Ohmic value of the current sense resistor, which degrades the short circuit and overload protection. ...not only that but Ridley says that one should never derive the slope ramp from the clock oscillator of the PWM ic, even if via a BJT buffer is used...since it makes the SMPS more noise prone. Also, 47uH is the right value for the non-coupled inductors.....but if i simply make this the value for the coupled inductors.....then it will appear to be 94uH (due to mutual inductance).....and that surely is a bad thing because i need the inductor to be small Henry value , so as to allow a good, fast transient response. ....the increased value of inductance when coupled, is the same as in a SEPIC converter, where coupling the two inductors halves the input current ripple, since it makes the inductance twice as much. So shouldnt i use 47/2 uH for the coupled inductor value (individually)? ["47/4", as in my previous , was an error, sorry] |
#9 |
Well, about the inductance value... You have most likely calculated your desired value for a single output based on a tradeoff between mainly minimum output current (for the "critical inductance" value) and ripple current (sizing the output capacitors for the desired ripple voltage).
In steady state balanced load operation, there isn't any "transformer action" going on in the coupled inductor core, so you can treat the winding inductances as if they were independent. You needed 47 uHy in a single choke, so you still need 47 uHy on each of the windings. Above the DC critical load current, the AC ripple current in the +50V winding goes through the +50V output capactitor, then through the -50V output capacitor and into the -50V leg of the coupled inductor. AC current in the return leg cancels. The voltages across the two windings are the same during the ON and OFF switching intervals. Each winding has to have the value of inductance that you would have chosen for separate cores if you are going to have the desired ripple current in your output capacitors. Each winding will have the same number of turns on it that you would have had if you used two of the same type of core and wound two inductors. The H in the single core will be twice the H of the separate cores, so it doesn't save any core material to use a coupled inductor. The effective "load" that the output with coupled inductors presents to the secondary of the transformer is exactly the same as if you had separate cores (i.e. it "looks" as if you have two 47 uHy inductors in parallel and the +/-50V output caps in parallel driven by a single secondary). There's a lot more to be said about the inductor if you think more needs to be said. |
#10 |
Thanks neophyte, that is interesting..... I chose the inductor so that it has a lot of ripple.....to give a fast transient response. -but i didnt want too high peak current, so i chose the inductor value such that the inductor currnt was in boundary mode at Maximum load, Maximum input line voltage. ....So basically, in half load, or light load, my output inductors should be in discontinuous mode...............and i am wondering if the coupled inductor principle still works when there is discontinuous mode? So i take it from the fact that a bigger core is needed for the single coupled part that each inductor of the coupled inductor is connected in like flyback transformer inductors.?...i.e. they both make the flux lines go the same way when they flow current.?...... |
| Class D SMPS...with coupled inductor output? | eem2am | Power Supplies | 0 | 20th August 2011 07:59 AM |
| Coupled output inductor in BTL? | Khron | Class D | 28 | 30th June 2010 02:27 AM |
| DC on output of Chinese 'current mode' ebay amplifier | ben12345 | Solid State | 20 | 28th May 2010 08:27 AM |
| coupled output inductor in dual smps | schiller | Power Supplies | 4 | 7th April 2010 08:10 PM |
| UC3846 current mode control vs. SG3525 with average current mode control | mflorin | Power Supplies | 32 | 4th November 2009 04:43 PM |
| Page generated in 0.12957 seconds (82.92% PHP - 17.08% MySQL) with 10 queries |
