Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th September 2011, 09:20 PM   #1
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Default 100V rated caps @ 35V
Any thoughts on running 100v rated caps @ 35 volts in a PSU, any negatives attached to doing so ...?
Old 16th September 2011, 09:31 PM   #2
nigelwright7557's Avatar
As long as ESR and value are the same shouldnt make a difference.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 17th September 2011, 11:36 AM   #3
marce is offline marce  United Kingdom
Yes, caps are better if de-rated by 50%, when MTBF figures are calculated you have to de-rate them by at least 50% to get a decent result.
Old 17th September 2011, 01:17 PM   #4
RJM1 is online now RJM1  United States
As long as they fit, also see the previous two posts.
Old 18th September 2011, 04:46 AM   #5
a.wayne's Avatar
Thanks for the response guys ...
De-rate are you saying view the 100 v cap as a 50 V ...?
Well, I have some 50v caps that i just might end up using instead of the 100v units, they have lower esr's ..
Old 20th September 2011, 11:47 AM   #6
Yes, if you can afford the higher voltage rating, dont forget also the occasional spike etc can hit equipement. The 50V cap will also work. When any high reliabilty products are designed, electroyiticas are always de-rated 50%, otherwise you dont get the required MTBF figures.
Old 20th September 2011, 01:09 PM   #7
DF96 is online now DF96  England
If you run 100V electrolytics at 35V for many years they can become, in effect, 35V caps. Fine while in situ. Problems can come if you re-use them for another project where they have much higher voltage across them. You would first have to re-form them back up to a higher voltage.
Old 20th September 2011, 11:53 PM   #8
Ron AKA is offline Ron AKA  Canada
Check out the new Panasonic FR series caps. They only go up to 50 V but have some pretty impressive ESR values, life (10,000 hrs), and capacitance for a given size. But, to your question no harm in using over voltage rated caps. Often you can get more ripple current capacity and ESR for a given capacitance (but at a price in capacitor physical size).
Why use High Voltage rated caps in Xover? plmedeiros Multi-Way 8 9th October 2010 10:24 AM
4700Uf 35v Suntan Caps Wizardmaxx Swap Meet 0 19th October 2009 12:53 PM
WTB: 35V snap-in caps large capacity len_scanlan Swap Meet 0 2nd March 2009 11:27 PM
FREE Y2 rated CAPS HIPCHECK Swap Meet 0 21st October 2006 11:15 AM
free 35v caps xplod1236 Parts 4 4th January 2004 06:20 AM
Page generated in 0.10481 seconds (77.09% PHP - 22.91% MySQL) with 10 queries
