Hi guys,
I have built an amp that seems to work well, however every couple of hours I seem to get a random loud pop from the speakers. I haven't noticed this when running a 25V transformer, but I do when using a 30V one. The PSU smoothing caps are rated at 50V so the rectified 30V comes pretty close at ~46V. It is difficult to fit higher voltage rated caps due to size limits. What is the cause of this? I thought maybe the caps are building up and then leaking all of a sudden into the circuit? If so, is it possible to put a couple of high value (?R) resistors across each cap? Thanks! |
#2 |
not especially a power supply issue eventhough could be
any of the parts of your amplifier overheating from wrong calculation or missplacement state more about the amp ...pictures also might help .... and a soldering check might also bring something up kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 |
Have any other equipment with motors on this mains AC circuit, perhaps an air conditioner/etc. is kicking off creating a surge?
#4 |
yeap !!! also a very good posibility ...sorry i missed that
#5 | |
soon to be: papa's Class A all the way
#6 | |
High value resistors would not be expected to solve this, although having them as bleeder resistors so the caps drain to a low level more quickly when the amp is turned off can be useful if the amp doesn't have a mute function, and for safety in case someone were to be working with the power supply components and didn't want a charge still in the capacitors. |
| Carver amp pops on right channel | CharlieM | Solid State | 0 | 11th October 2010 10:19 AM |
| My DIY Pre amp switcher pops! | MuthaFunk | Parts | 5 | 6th May 2009 02:07 PM |
| Clicks & pops with TDA1543 x8 DAC? | fluckscapacitor | Digital Source | 19 | 18th November 2006 12:11 AM |
| Pioneer SX-1250 amp pops / crackles | 8Track | Solid State | 38 | 17th July 2005 03:00 AM |
| Amp pops on power down? | jjai | Instruments and Amps | 2 | 8th March 2005 08:26 PM |
| Page generated in 0.07860 seconds (83.23% PHP - 16.77% MySQL) with 10 queries |
