hi guys
i have MBR7030wt with spec 70a 30v. i am wondering if it is safe to use it to rectifier transformer secondary 0-18v to get 24vdc? i am running it for class A amplifier that draws around 1.8a. i have 100.000uf after the rectifier. and the loaded voltage is 23v. i am wondering if the MBR7030wt within safe operating range? thanks in advance Erwin |
#2 |
Yes it is within safe operating range. The only concern would be that without much voltage margin, if your AC mains suffered a power surge, it could exceed the rectifier's rated voltage... but this is always a concern with power surges and electronic gear, it just becomes progressively more concerning as the voltage rating comes closer and closer to the transformer output voltage rating. I would go ahead and use them unless you know the AC input is subject to frequent surges.
#3 |
Hi Erwin,
I suppose that you are using 4 of them in brigde configuration. In this case every diode of the bridge will see a maximum reverse voltage of 18*sqrt(2)=25.5v. Note that the line voltage is specified at +/-15% of its rated voltage so in the worst case the diode will see 18*1.15*sqrt(2)=29.3v. Your diode is rated 30v an a schottky diode is not at all tolerant to overvoltage. The diode is in its rating but with a margin of only 0.7v.... I would not use this diode but use a diode rated minimum 45v of vrrm. Btw. Why such a big diode? Why a schottky diode? You are wasting a lot of watts in running your amp in class A so why improving the efficiency of the rectifier bridge using low voltage and high current schottky? Use a standard 25A/100V bridge and you are fine. Ciao -marco |
#4 |
#5 |
^ That's an interesting thought but then how do you explain those who use schottkys rated for less than double the forward voltage without having them fail?
#6 |
thanks for the inputs guys.
how bout put 2 of them in series? would it double the PIV or what the term? erwin |
| 5C8S rectifier psud2 modle/rectifier information | ryuji | Tubes / Valves | 1 | 14th March 2011 04:54 PM |
| converting tube rectifier to solid state rectifier. | tubo | Tubes / Valves | 26 | 24th December 2009 12:12 AM |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Page generated in 0.08583 seconds (76.84% PHP - 23.16% MySQL) with 10 queries |
